Problem with registration
12 years 2 months ago #172961 by Odda
-- Joomla version -- : 2.5.25
Under "Login and Registration" I have selected "Simplified registration with password" and set "Ask address on registration" to yes. When I register as a new customer and write all info (including address and phone) and press OK, I get a blank page. I've read that this maybe caused by the template, and I'm trying to figure this out with the developer of the template. BUT: the user is saved and logged in, so the registration seems to work except one thing: all the address-information is lost, so when checking out after putting something in the shopping basket, I'm once again asked to register my address. Any idea how to solve this issue?
12 years 2 months ago #172964 by nicolas
Replied by nicolas on topic Problem with registration
Please try again after activating the "error reporting" and "debug mode" options of the joomla configuration.
That should display an error message which will help us understand the problem you have.
12 years 2 months ago #173125 by Odda
Replied by Odda on topic Problem with registration
This is what I get:
Warning: is_readable() [function.is-readable]: open_basedir restriction in effect. File(/dev/urandom) is not within the allowed path(s): (/home/:/tmp/:/usr/lib/php5/:/usr/share/php:/usr/local/php5-suphp/:/usr/bin/:/usr/local/bin/:/bin/) in (...)/www/libraries/phpass/PasswordHash.php on line 51
Fatal error: Call to undefined function acymailing_get() in (...)/www/plugins/hikashop/acymailing/acymailing.php on line 68
12 years 2 months ago #173152 by nicolas
That would indicate that you have a really old version of AcyMailing installed on your website. If that's the case, maybe it's a good time to update it :)
Otherwise, just unpublish the hikashop acymailing plugin via the Joomla plugins manager and that will avoid the problem.
12 years 2 months ago #173187 by Odda
An old (and not in use) version of AcyMailing seemed to be the problem. After deactivation it seems to work perfect once again! Thanks for excellent and quick support :)
12 years 1 month ago #173773 by nuevaera
Replied by nuevaera on topic Problem with registration
Hi, I have the same problem, but now the disable AcyMailing, but I still have the same error, no data are recorded customer address, attached the image of the message it gives me. Please help me :(
productosnuevaera.com/
Productos Nueva Era | Un Mundo de Regalos Místico para ti
12 years 1 month ago #173775 by Jerome
Replied by Jerome on topic Problem with registration
Please provide some useful information like your HikaShop version number and details of your current error (the screen shot something but I don't know how you got it).
12 years 1 month ago - 12 years 1 month ago #173944 by nuevaera
my system is Joomla! 2.5.24 with HikaShop Business 2.3.3
Last edit: 12 years 1 month ago by nuevaera.
12 years 1 month ago #173959 by nuevaera
my system is Joomla! 2.5.24 with HikaShop Business 2.3.3, the problem is that in any register forms when you put the address is registered, the user is logged, but the address data is lost, do not appear, and you can not checkout .
12 years 1 month ago #173986 by Jerome
Are you using falang ?
Would it be possible to have an access to your backend ?
12 years 1 month ago #174093 by nuevaera
Hi!,
no, i´m not using falang.
Yes, I can give you access but give it please explain to me how.
I require to solve this problem as quickly as possible
12 years 1 month ago #174096 by nuevaera
I already gave privileges to the user created in the backend site
12 years 1 month ago #174101 by nicolas
It looks like there is a problem with the custom address fields in your database.
Plese turn on the "debug mode" option of the joomla configuration and try again to register and it should display an error message explaining the problem if that's indeed coming from that.
Also, you can try to disable the custom fields that you created/modified via the menu Display->Custom fields. That should hopefully solve the problem. Then, you can try to recreate them.
12 years 1 month ago #174282 by nuevaera
Hi .. Thanks, yes, it was a custom field that blocked the registration, unpublish and now i can register the address, but as it is a data that really I require (it is a number of citizen identification), I went back to create, but when I fill in the form recorded everything except this, do not appear in the data, and I need it to appear there and on invoices.
12 years 1 month ago #174364 by Jerome
What do you mean by "not appear in the data" ?
If you want to change the way that the addresses are displayed, you have to override the view "address_template" (for your front-end template and your back-end template).
www.hikashop.com/support/documentation/i...ashop-view-form.html
11 years 11 months ago #183952 by andreag
Replied by andreag on topic Problem with registration
HikaShop essential 2.3.4
Joomla 3.3.6
I got a problem with account registration; a error box is shown "Error: Access Usergroup Invalid" and even though the registration is successful no address is recorded in the profile and is again asked during checkout. I switched on debug mode and see this message "Notice: Undefined index: user in /home/prodotti/public_html/plugins/system/hikashopusergroup/hikashopusergroup.php on line 40"
How can I fix this problem?
Andrea
11 years 11 months ago #184022 by nicolas
Try to disable the HikaShop group plugin via the Joomla plugins manager.
11 years 11 months ago #184432 by andreag
thank you! it did work. Only there was still a small problem with some links directing to the Joomla deafult registration form, leading to the same problem of missing address on the stored profile. I found a solution on a different post. Here the link, hope can be helpful if someone has this issue too:
www.hikashop.com/forum/3-bug-report/8726...trationredirect.html
Time to create page: 0.122 seconds
