Using the Products Limit feature
6 years 1 month ago - 6 years 1 month ago #323612 by vanboke
-- Joomla version -- : 3.9.21
I am not sure if this is the correct category to post this, as there isn't one that looks to fit this question.
I am looking to use the Products Limit feature of HikaShop and have a question.
In the documentation for the feature and the restrictions, it says the following for product and category:
Product : If you want restrict your filter to one or several products.
Category : Same idea than previous, but for one or several categories.
It clearly says both are for "one or several products". However, I can only ever add one product or category to those fields.
Is this by design and the documentation is wrong, or is the documentation right and I should be able to add multiple products and categories to those fields?
A little clarification on my questions.
I am managing some websites that are selling online courses. The courses are sold through Hikashop and then they are enrolled in the courses within Moodle through Joomdle.
I need to limit all courses on the website so that they can only be purchased once. If I choose a to limit to a quantity of 1 by a single category, they are only able to purchase one course in the whole category. This seems odd to me. I get it form one perspective, but I would think this is a pretty limited use case. There should be a switch in the setup of the limit so that it could be either one course out of the whole category OR one of each of the courses in the category. That isn't the case though.
At the moment, the only way I can see how to do what I need done is to add a separate limit for each and every product that represents a course. This is a huge pain, and turns into one more thing that could be missed when setting up a new course.
Anyone have any ideas?
Last edit: 6 years 1 month ago by vanboke. Reason: Added more information.
6 years 1 month ago - 6 years 1 month ago #323615 by nicolas
It is by design and the documentation is wrong.
Thanks for you feedback. I've updated it.
Regarding your situation, note that if you don't select any category or any product, then the limit will apply to all of them.
Having more complex capabilities to select several products / categories or exclude products / categories would be possible. But that means extra development, extra complexity, and slower processing to be able to take all the cases into account (more MySQL queries, more checks for edge cases, etc).
Now for advanced restrictions, it might be better to have a dedicated plugin custom developed to enforced the limits exactly how you need them rather than complexify the system available.
Last edit: 6 years 1 month ago by nicolas.
6 years 1 month ago #323654 by vanboke
Thank you for the information. I do have another question though. You said:
"Regarding your situation, note that if you don't select any category or any product, then the limit will apply to all of them."
I didn't know that, but it begs a question. After seeing how limits work when selecting a category, how would it work if I set the quantity to 1 and didn't choose a product or a category. Would it mean that all user are limited to only buying 1 product within the whole store? If so, that is a pretty ridiculous scenario and I can't imagine why you folks would design limits that way.
Please clarify how limits would work in that case, and maybe let me know how you intended this feature to work in general. At the moment, I am seeing a limited use for limits within Hikashop with how I am seeing it behaving.
6 years 1 month ago #323655 by vanboke
I just performed a test, and not selecting any products or categories, does indeed apply the limit to all products in the store. However it did exactly what I suspected it would do.
Setting a limit of 1 for quantity limits the users to only being able to purchase a single product on the website.
This is pretty ridiculous. The use case I need, where a user in only able to purchase any one product only once is to me a basic thing, but with Hikashop seems to be difficult to achieve. I guess I don't understand why product limits was designed to be so, well, limited. Sorry for the pun.
I can only conceive of limited uses for the limits feature. So limited in fact that I don't understand why it was designed the way it is in the first place.
It looks like my only recourse would be to create a separate limit for each product in the store, which honestly is ridiculous as it is cumbersome to maintain. Or spend money to have a custom plugin developed to give me a feature that honestly should be part of the core of Hikashop, in my honest opinion.
I would like you folks to reconsider how you have limits designed to function. This to me is a huge issue within Hikashop as the feature and how it is implemented to function makes little sense.
6 years 1 month ago #323657 by nicolas
It depends on the duration you configure. If you configure the duration to be "forever", then yes, the customers would only be able to buy 1 product on the shop once.
I don't see why anyone would do that either, but you never know.
I remember however someone managing a big company using HikaShop for a website they had setup for their employee to order free products, limited to 3 products every quarter per employee. So the limit system would allow for that with a similar rule on all the shop.
I also remember several merchants using the limit system to limit the purchase of one product per cart on the whole store for different reasons (shipping reasons, payment reasons, etc).
Now I don't really see why you're so upset about this feature. I think you're missing something in the way you want to use it. Why not create an unpublished category called "limit number 1" and configure your limit to apply to that category only ? Then, you could add that category as a second category to the products on which you want the limit to apply regardless of where the products are in the tree of categories on your shop. That way, no need to create a limit for each product. You can easily add or remove a limit on a product, you can easily see the listing of the products on which the limit apply by going to the listing of products and selecting that category in your backend, and if you want to add / remove a bunch of products from a category to that limit, you can do it with a mass action using a filter on a category and an action to add / remove that unpublished category.
6 years 1 month ago #323777 by vanboke
Unfortunately this approach does not work, which is the source of my frustration with how limits are working. If I do exactly what you are suggesting then only 1 product of any of the products in that category can be purchased. What I need is only 1 of each product can be purchased.
It is the difference between one and many. If I choose a category for the limit I need the limit to apply to individual products not all of the products as a whole. It does no good to put a quantity limit on a category of 1, only to have Hikashop limit things so that the user can purchase only one of the products in the category.
Am I making sense?
I see how you folks have the feature implemented, but I see only limited use cases for ever using it as it is implemented.
Can you think of any solutions besides me creating limits for each and every product in the store?
6 years 1 month ago #323780 by nicolas
If you want to target only one product, you have the "Quantity per order" setting in the settings of the product itself to limit the purchase of a product for each order. So no need to use the limit system.
The only case not convenient would be if you want to limit to one product per account and not per cart.
In that case, it would indeed require creating one limit per product to be able to do that. And the only way to avoid doing that would be some kind of development to either generate automatically the limits or add an extra option to the limits system or to not use the limit system and handle the restriction directly on the cart.
So I see the opposite of you here. I see most of the use cases I can think of possible easily, with only one case demanding some cumbersome setup or extra development.
If you're in that case, then I can understand you're frustrated but I can't provide a read-made solution I don't have.
6 years 1 month ago #323795 by vanboke
Since I need to have the limit set up to one purchase of a product forever, not just in an order, since it is a course that they are not allowed to purchase again, it looks like I am left with no solution except to create a limit for each product.
I know for a fact that I am not the only person that has needed this exact type of limit. There are many requests for that exact type of limit within the forums. None of them have any workable answers either, but most of them were before the products limit feature was released.
Again, I am surprised that you don't have a flag within the limits when choosing a category to have it work on ALL PRODUCTS or EACH PRODUCT. Since people besides me have asked about this feature going back to 2011-2012 I find it hard to believe that it isn't an available option.
I guess I have my answer though. There isn't an easy solution within HikaShop. I will need to do it the hard way.
6 years 1 month ago #323808 by nicolas
Well, since the addition of the limit system in HikaShop, I don't remember anyone asking for what you want to do (maybe there were one or two ?). But compared to other features where we had tens of requests it's not a priority.
Still, I've added that on our todo list so hopefully it will be added at some point in the future.
Thanks for your feedback on the matter and the explanations of your use case.
3 years 3 months ago - 3 years 2 months ago #353357 by dvddvd
Hello Nicolas,
is it possible in any way to limit that only one type of product can be added to the cart, but that several units of it can be purchased?
Let me explain, that there cannot be more than two different items in the cart, but several units can be ordered.
I know it's weird, but it would be very useful.
Thanks again Nicholas.
Last edit: 3 years 2 months ago by dvddvd. Reason: unsolved
3 years 2 months ago #353375 by nicolas
Do you mean that if you have product A, product B and product C, you only want maximum A and B, or B and C, or A and C in the cart, but the quantities can be whatever ?
There is no such capabilities. I think it would require a custom plugin to be developed to enforce such a restriction.
However, in some cases, an alternative solution would work.
If we go back to my example, if you create two products in an unpublished category, with A, B and C being variants in each product, and then you add both as options of a main product, the user will have to choose among these 3 choices on both options on the product details page of the main product. So it would meet your requirements. But this setup might be impractical in some cases.
3 years 2 months ago #353402 by dvddvd
Yes, that would be the case, but only one product would be added to the cart. Between A, B, C only A or B or C. Only one product_code per cart, ... but being able to choose any quantity of that product.
Thsnks
3 years 2 months ago #353416 by nicolas
A product with one option and three choices in that option (A, B and C) would allow you to do that. How about it ?
