Cart does not clear after checkout AND after time limit for cart retention
3 years 10 months ago #347646 by Dragon41673
-- HikaShop version -- : 4.7.0
-- Joomla version -- : 3.10.11
Not sure why, but I just recently noticed that the time for cart retention is not working, and I have carts dating back to over a year. I've been manually deleting them, but this is tedious. I originally had it set to 30 days, but I've changed it to 5 days, and it STILL holds on to carts well after that time limit. Screenshots attached
During this time, I have had 3 customers contact me to complain that previous carts were being loaded while trying to checkout, one of which I had to refund.
What needs to be done to fix this?
3 years 10 months ago #347650 by nicolas
Your problem is the "frequency" setting.
You've set it to 1 week. This means that the system will only delete old carts once a week.
Also, HikaShop is only deleting 50 carts each time to avoid crashes.
Rather than reducing the "cart retaining period", you should reduce drastically the frequency so that more carts can be handled every day. For example, you could set the frequency to 1 minute so that it would quickly get rid of old carts.
3 years 10 months ago - 3 years 10 months ago #347663 by Dragon41673
Fantastic I will give that a try thank you!
Last edit: 3 years 10 months ago by Dragon41673.
3 years 10 months ago #347688 by Dragon41673
So I kept the 5 days for the cart clearing, and dropped the frequency down to 5 minutes yesterday, and after a couple hours, it still wasn't working. Thinking maybe I needed to extend it a bit more, I pushed it up to 30 minutes and let it go over night...it's still not working.
Any other thoughts here? I'm having to manually delete 1400 carts over a year timespan because it isn't doing it on its own.
3 years 10 months ago #347690 by nicolas
Note that this mechanism doesn't use the cron, since it wouldn't work with the Starter edition.
It works when you access a page in the backend.
So if you configure it to 5 minutes, it will delete 50 old carts next time you display a page in the backend as long as you displayed the last one more than 5 minutes ago.
And thus, if you don't do anything in your backend (like during the night) it won't do anything.
So with a frequency of 5 minutes, it could delete 1400 carts in a day, but you would have to browse your website backend a lot on that day.
3 years 10 months ago #347693 by Dragon41673
nicolas wrote: Hi,
I did not know that...I'll do what I can, thank you!
Time to create page: 0.318 seconds
