Add product to cart using a plugin
10 years 4 months ago #245011
by Rixters
Add product to cart using a plugin was created by Rixters
-- Joomla version -- : 3.5.1
-- PHP version -- : 7.0.9
-- Browser(s) name and version -- : FF
Because Hikashop doesn't provide a functionality to add a product for free when a certain cart amount is met, I'm trying to build a plugin who does that for me. Could you provide a code sample how to add a product to the cart when a plugin event is fired? can I also then reset the the price to 0?
Hope you can get me started...
10 years 4 months ago #245020
Replied by nicolas on topic Add product to cart using a plugin
On this thread, we talk about adding a product to the cart with either a redirect, a form submit, or code:
www.hikashop.com/forum/2-general-talk-ab...-product-fields.html
But it's actually quite easy to do:
$class = hikashop::get('class.cart');
$class->update($product_id, $quantity);
10 years 4 months ago #245107
by Rixters
Replied by Rixters on topic Add product to cart using a plugin
Great! That worked!
Just to be complete. Can I also remove a product from the cart or change the price using this class?
Thanks for the help!
10 years 4 months ago #245109
Yes, and it's really easy. It's the same function with the quantity being 0 :
$class->update($product_id, 0);
Also note that the quantity is not added by default, it replaces the quantity of the product in the cart.
If you want to add a quantity of 2 to the quantity already in the cart, you need to do like that:
$class->update($product_id, 2, true);
The following user(s) said Thank You: Rixters
10 years 4 months ago #245183
by Rixters
With your help I created a plugin that add a free product to the cart depending on the total cart price. github.com/RickR2H/hikashop-free-product
Thanks for the help and regards!
10 years 4 months ago #245185
by kyratn
Replied by kyratn on topic Add product to cart using a plugin
Thanks for the share. It can be very useful...
10 years 3 months ago #246528
by Siberio87
Replied by Siberio87 on topic Add product to cart using a plugin
thank you sir for the plugin!
6 years 6 months ago #317785
by ynnadje
Replied by ynnadje on topic Add product to cart using a plugin
Thank you Nicholas,
This is a very usefull plugin. Could I add multiple products depending on the cart-total.
example
If you buy for 30€, you receive free product B
If you buy voor 100€ you receive product A + B
When buying for 500€, you receive products A + B + C
example
6 years 6 months ago #317792
With the plugin on our marketplace ( www.hikashop.com/marketplace/product/118...on-free-product.html ) you can do:
If you buy for 100€ you receive product A
When buying for 500€, you receive products C
But you can't have it add several products at once. That would require some development in the plugin to support it.
4 years 58 minutes ago #346503
by bansi
Replied by bansi on topic Add product to cart using a plugin
how to fetch the product id for all different products?
3 years 11 months ago #346549
Where do you want to do that ? What information of the products you have at hand ?
Time to create page: 0.087 seconds
