- Thank you received: 20
Products order for inserted products in articles (simple solution provided)
5 years 2 months ago #335586
by dyvel
To order by the order of ids, I modified the file: plugins/system/hikashopproductinsert/hikashopproductinsert.php
in line 279:
Change:
To this:
Now the order is respected.
I hope you will consider adding this to the plugin for the next update?
Have a nice day." class="hasTooltip topictitle">Products order for inserted products in articles (simple solution provided) was created by dyvel
-- Joomla version -- : 3.10.1
-- PHP version -- : 7.4
Often, when I use the hikashopproductinsert plugin to insert products in articles, I need the products to be in a specific order - as in the order I add the ids, but as of now, the order is not respected in the query (it's missing an order by).
Just for reference, I insert products like this:
in line 279:
Change:
To this:
Have a nice day.
in line 279:
Change:
$product_query = 'SELECT * FROM ' . hikashop_table('product') . ' WHERE product_id IN (' . implode(',', $ids) . ') AND product_access='.$db->quote('all').' AND product_published=1';
To this:
$product_query = 'SELECT * FROM ' . hikashop_table('product') . ' WHERE product_id IN (' . implode(',', $ids) . ') AND product_access='.$db->quote('all').' AND product_published=1 ORDER BY FIELD(product_id, ' . implode(',', $ids) . ')';
Have a nice day.
5 years 1 month ago #335608
in line 279:
Change:
To this:
Yes, we can add that modification.
Thanks for your feedback and contribution.
Time to create page: 0.040 seconds
