No products left after deleting filter
11 years 2 weeks ago #213938
by Ziggy
No products left after deleting filter was created by Ziggy
-- HikaShop version -- : 2.50
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.4.43
-- Browser(s) name and version -- : Opera
After applying a filter, based on characteristics, the filter works well.
Unfortunately after deleting the filter, no products are left.
Does it sound familiar to someone and know how to solve this issue?
I don't have the same problems using filters based on other brand of price
11 years 2 weeks ago #213991
Replied by nicolas on topic No products left after deleting filter
I don't know about such issue.
Can you try to turn on the "redirect POST mode" setting of the HikaShop configuration page and see if that helps ?
Could you also provide a screenshot of your characteristics filter settings page and one of your characteristic settings page ?
11 years 2 weeks ago - 11 years 2 weeks ago #214108
by Ziggy
Replied by Ziggy on topic No products left after deleting filter
Last edit: 11 years 2 weeks ago by Ziggy.
11 years 2 weeks ago #214114
I've checked your website and now the products are displayed back after reseting the color filter.
So it seems to be working.
Can you confirm ?
Can you confirm ?
11 years 2 weeks ago - 11 years 2 weeks ago #214200
by Ziggy
Cause of adding a reset button, yes.
But no products are shown when you add a color filter.
In the screenshot you can see the characteristics is added to the products
update: If i add a filter by brand first, the color filter works like a charm, but otherwise it shows no products. I am curious.
11 years 2 weeks ago #214249
by Jerome
Replied by Jerome on topic No products left after deleting filter
It looks like a "reset" issue with the filter which use an empty value instead of clearing the filter content.
Would it be possible to have a description to reproduce the issue in your website ?
We need to see the filter organisation in your page and if possible could have access to the SQL debug.
Thanks to that, we will be able to trace the source of the issue and create a patch.
11 years 2 weeks ago #214335
by Ziggy
Could be a issue by reset button, but for what reason does it work after filtering by brand or sort first?
For me, it looks like an issue filtering by characteristics.
11 years 6 days ago - 11 years 6 days ago #215089
by Ziggy
Last edit: 11 years 6 days ago by Ziggy.
11 years 6 days ago #215110
by Ziggy
I deleted the brand filter and add the filter by brand as a characteristic.
Now its works like a charm
Time to create page: 0.219 seconds
