No products left after deleting filter
11 years 2 months ago #213938 by Ziggy
-- HikaShop version -- : 2.50
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.4.43
-- Browser(s) name and version -- : Opera
After applying a filter, based on characteristics, the filter works well.
Unfortunately after deleting the filter, no products are left.
Does it sound familiar to someone and know how to solve this issue?
I don't have the same problems using filters based on other brand of price
11 years 2 months ago #213991 by nicolas
I don't know about such issue.
Can you try to turn on the "redirect POST mode" setting of the HikaShop configuration page and see if that helps ?
Could you also provide a screenshot of your characteristics filter settings page and one of your characteristic settings page ?
11 years 2 months ago - 11 years 2 months ago #214108 by Ziggy
the screenshots:
Filter
Characteristics
Products
Products variants
Last edit: 11 years 2 months ago by Ziggy.
11 years 2 months ago #214114 by nicolas
I've checked your website and now the products are displayed back after reseting the color filter.
So it seems to be working.
Can you confirm ?
11 years 2 months ago - 11 years 2 months ago #214200 by Ziggy
Cause of adding a reset button, yes.
But no products are shown when you add a color filter.
In the screenshot you can see the characteristics is added to the products
update: If i add a filter by brand first, the color filter works like a charm, but otherwise it shows no products. I am curious.
11 years 2 months ago #214249 by Jerome
It looks like a "reset" issue with the filter which use an empty value instead of clearing the filter content.
Would it be possible to have a description to reproduce the issue in your website ?
We need to see the filter organisation in your page and if possible could have access to the SQL debug.
Thanks to that, we will be able to trace the source of the issue and create a patch.
11 years 2 months ago #214335 by Ziggy
Could be a issue by reset button, but for what reason does it work after filtering by brand or sort first?
For me, it looks like an issue filtering by characteristics.
11 years 1 month ago - 11 years 1 month ago #215089 by Ziggy
I am wondering what to do to solve this issue
If i select "merk" first. All filters work.
If i filter of the other filters firs. No results are shown and i need to reset the filter to continue.
Jerome has credentials to login to the backend
Last edit: 11 years 1 month ago by Ziggy.
11 years 1 month ago #215110 by Ziggy
I deleted the brand filter and add the filter by brand as a characteristic.
Now its works like a charm :-)
