- Thank you received: 8
problem order selection using calendar
12 years 5 months ago - 12 years 5 months ago #152279
by Udo
problem order selection using calendar was created by Udo
-- Joomla version -- : 1.5.26
-- PHP version -- : 5.3.21
I have a problem with the data filtering of the orders in the backend.
When selecting a From or To date (by typing or by clicking the calendar) the date jumps to 1970-01-01. This can only be restored by logging out.
This happens using Firefox and also using Chrome.
regards,
Udo
regards,
Udo
Last edit: 12 years 5 months ago by Udo. Reason: Typo in subject
12 years 5 months ago #152284
by Jerome
Replied by Jerome on topic problem order selection using calendat
Can you reproduce the problem in our demo website ?
Would it be possible to have an access to your website in order to see the problem directly ?
12 years 5 months ago #152422
by Udo
Replied by Udo on topic problem order selection using calendar
Hi Jerome,
In the demo website the order selection works fine.
I´ll send a PM about the access to the site.
regards,
Udo
regards,
Udo
12 years 5 months ago #152584
by Xavier
Replied by Xavier on topic problem order selection using calendar
I don't find the page you are talking about.
Thanks to give us a direct link to the page with the problem.
12 years 5 months ago #152592
by Udo
It's in the backend, the Hikashop menu Orders.
The filtering on the top, the fields 'From' and 'to'.
Udo
Udo
12 years 5 months ago - 12 years 5 months ago #152598
by Xavier
I made the correction on your end directly.
The modification was to edit the view "order / listing" in the backend template and replace:
By:
echo JText::_('FROM').' ';
echo JHTML::_('calendar', hikashop_getDate((@$this->pageInfo->filter->filter_start?@$this->pageInfo->filter->filter_start:''),'%Y-%m-%d %H:%M'), 'filter_start','period_start','%Y-%m-%d',array('size'=>'10','onchange'=>'document.adminForm.submit();'));
echo ' '.JText::_('TO').' ';
echo JHTML::_('calendar', hikashop_getDate((@$this->pageInfo->filter->filter_end?@$this->pageInfo->filter->filter_end:''),'%Y-%m-%d %H:%M'), 'filter_end','period_end','%Y-%m-%d',array('size'=>'10','onchange'=>'document.adminForm.submit();'));
echo JHTML::_('calendar', hikashop_getDate((@$this->pageInfo->filter->filter_start?strtotime(@$this->pageInfo->filter->filter_start):''),'%Y-%m-%d %H:%M'), 'filter_start','period_start','%Y-%m-%d',array('size'=>'10','onchange'=>'document.adminForm.submit();'));
echo JHTML::_('calendar', hikashop_getDate((@$this->pageInfo->filter->filter_end?strtotime(@$this->pageInfo->filter->filter_end):''),'%Y-%m-%d %H:%M'), 'filter_end','period_end','%Y-%m-%d',array('size'=>'10','onchange'=>'document.adminForm.submit();'));
Last edit: 12 years 5 months ago by Xavier.
The following user(s) said Thank You: Udo
12 years 5 months ago #153065
by Udo
Thanks Xavier, this solved the problem.
One remark: after selecting (for instance) 2014-04-08 the result is 2014-04-07 23:00
This may be caused by the time zone in the global configuration?
Udo
Udo
12 years 5 months ago #153082
Replied by nicolas on topic problem order selection using calendar
Use that code instead and you wont' get the hours:
echo JHTML::_('calendar', hikashop_getDate((@$this->pageInfo->filter->filter_start?strtotime(@$this->pageInfo->filter->filter_start):''),'%Y-%m-%d'), 'filter_start','period_start','%Y-%m-%d',array('size'=>'10','onchange'=>'document.adminForm.submit();'));
echo JHTML::_('calendar', hikashop_getDate((@$this->pageInfo->filter->filter_end?strtotime(@$this->pageInfo->filter->filter_end):''),'%Y-%m-%d'), 'filter_end','period_end','%Y-%m-%d',array('size'=>'10','onchange'=>'document.adminForm.submit();'));
12 years 5 months ago #153237
by Udo
Thanks for the support. Indeed, I the hours don't show, but still the date changes.
No big problem.
Udo
No big problem.
Udo
Time to create page: 0.223 seconds
