[SOLVED]custom product field in order confirmation
- nico.van.leeuwen
10 years 9 months ago - 10 years 9 months ago #224718
by nico.van.leeuwen
-- Joomla version -- : 3.4.6
-- PHP version -- : 5.6
I'm trying to create a very stripped down version of the order creation email in plain text.
Now I would like to add a field to the row with the product lines.
This field is a custom field that is in the products and is called "gewichtsklasse". It's only visible in the backend.
I've been reading and tried something like this:
echo $data->cart->gewichtsklasse."\n";
But no luck yet. The line it should be appended to is now looking like this :
Thanks for any help.
<?php
foreach($data->cart->products as $item){
$price = $item->order_product_price*$item->order_product_quantity;
echo strip_tags($item->order_product_name) . "|" . $currencyHelper->format($item->order_product_price,$data->order_currency_id)."|".$item->order_product_quantity."|".$currencyHelper->format($price,$data->order_currency_id)."\n";
Last edit: 10 years 9 months ago by nico.van.leeuwen.
10 years 9 months ago #224757
Replied by nicolas on topic custom product field in text order confirmation
Can you provide a screenshot of the settings of your custom field ?
- nico.van.leeuwen
10 years 9 months ago #224761
by nico.van.leeuwen
Replied by nico.van.leeuwen on topic custom product field in text order confirmation
10 years 9 months ago #224767
If you want to include that in the code that you proposed in your first message, it would be:
<?php $productClass = hikashop_get('class.product');
$product = $productClass->get($item->product_id);
echo $product->gewichtsklasse;
- nico.van.leeuwen
10 years 9 months ago - 10 years 9 months ago #224823
by nico.van.leeuwen
Thanks for your reply,
It looks like it's working now, great !
Will check more and then mark this post as solved after that.
Time to create page: 0.185 seconds
