[SOLVED]custom product field in order confirmation
10 years 11 months ago - 10 years 11 months ago #224718 by nico.van.leeuwen
-- Joomla version -- : 3.4.6
-- PHP version -- : 5.6
I'm trying to create a very stripped down version of the order creation email in plain text.
Now I would like to add a field to the row with the product lines.
This field is a custom field that is in the products and is called "gewichtsklasse". It's only visible in the backend.
I've been reading and tried something like this:
echo $data->cart->gewichtsklasse."\n";
But no luck yet. The line it should be appended to is now looking like this :
<?php foreach($data->cart->products as $item){ $price = $item->order_product_price*$item->order_product_quantity; echo strip_tags($item->order_product_name) . "|" . $currencyHelper->format($item->order_product_price,$data->order_currency_id)."|".$item->order_product_quantity."|".$currencyHelper->format($price,$data->order_currency_id)."\n"; }
Thanks for any help.
Last edit: 10 years 11 months ago by nico.van.leeuwen.
10 years 11 months ago #224757 by nicolas
Can you provide a screenshot of the settings of your custom field ?
10 years 11 months ago #224761 by nico.van.leeuwen
Sure, the image is attatched.
10 years 11 months ago #224767 by nicolas
If you want to include that in the code that you proposed in your first message, it would be:
<?php $productClass = hikashop_get('class.product'); foreach($data->cart->products as $item){ $product = $productClass->get($item->product_id); $price = $item->order_product_price*$item->order_product_quantity; echo strip_tags($item->order_product_name) . "|" . $currencyHelper->format($item->order_product_price,$data->order_currency_id)."|".$item->order_product_quantity."|".$currencyHelper->format($price,$data->order_currency_id)."\n"; echo $product->gewichtsklasse; }
10 years 11 months ago - 10 years 11 months ago #224823 by nico.van.leeuwen
Thanks for your reply,
It looks like it's working now, great !
Will check more and then mark this post as solved after that.
