- Thank you received: 20
Adding Products To Orders In Admin
5 years 2 months ago - 5 years 2 months ago #334611
by davec
Adding Products To Orders In Admin was created by davec
-- Joomla version -- : 3.9.28
I have been contacted by my customer reference adding products to an order in the backend. Previously when adding a product he could see the quantity etc, but now he just has a product tree with no information. Is there a way to revert the display back to an earlier version as per the screenshot screenshot-2021.07.23-12_51_03. This is quite urgent!!
David
David
Last edit: 5 years 2 months ago by davec.
5 years 2 months ago #334613
Replied by nicolas on topic Adding Products To Orders In Admin
You can edit the file product / selection.php for your backend template via the menu Display>Views.
There, remove the whole code and copy / paste this code instead :
Then, save the view file override and you'll get back the previous interface.
<?php
$this->listing();
$shopCategoryType = hikashop_get('type.categorysub');
$this->shopCategoryType = $shopCategoryType;
if( !$this->singleSelection ) { ?>
<fieldset>
<div class="toolbar" id="toolbar" style="float: right;">
<button class="btn" type="button" onclick="hikashop_setId(this);"><img style="vertical-align:middle" src="<?php echo HIKASHOP_IMAGES; ?>add.png"/><?php echo JText::_('OK'); ?></button>
</div>
<script type="text/javascript">
function hikashop_setId(el) {
if(document.hikashop_form.boxchecked.value==0){
alert('<?php echo JText::_('PLEASE_SELECT_SOMETHING', true); ?>');
}else{
el.form.ctrl.value = '<?php echo $this->ctrl ?>';
hikashop.submitform("<?php echo $this->task; ?>",el.form);
</script>
</fieldset>
<?php } else { ?>
function hikashop_setId(id) {
var form = document.getElementById("adminForm");
form.cid.value = id;
hikashop.submitform("<?php echo $this->task; ?>",form);
</script>
<?php } ?>
<form action="<?php echo hikashop_completeLink('product'); ?>" method="post" name="adminForm" id="adminForm">
<div class="hk-row-fluid">
<div class="hkc-xs-6">
<?php
echo $this->loadHkLayout('search', array());
</div>
<div class="hkc-xs-6 hikashop_listing_filters">
<?php
echo $this->productType->display('filter_product_type',$this->pageInfo->filter->filter_product_type);
// Filters
if($this->config->get('show_category_explorer', 1)) {
echo $this->childDisplayType->display('filter_type', $this->pageInfo->selectedType, false, false);
</div>
</div>
<?php
if(!empty($this->breadcrumb)) {
<div class="hika_breadcrumb">
<?php
foreach($this->breadcrumb as $i => $breadcrumb) {
if($i > 0)
echo '<span class="sbreadcrumb_ep">/</span> ';
if($breadcrumb->category_id != $this->cid) {
echo '<span class="breadcrumb_el"><a href="'.hikashop_completeLink('category&task=listing&cid='.$breadcrumb->category_id).'">'.JText::_($breadcrumb->category_name).'</a></span> ';
} else {
echo '<span class="breadcrumb_el">'.JText::_($breadcrumb->category_name).'</span> ';
</div>
<?php
if($this->config->get('show_category_explorer', 1)) { ?>
<table id="hika_product_listing" style="border:0px;width:100%">
<tr>
<td style="vertical-align:top;width:1%">
<div id="category_explorer_btn" class="category_explorer_btn_hide">
<a href="#" onclick="return category_listing_hideshow(this);"><span><?php echo JText::_('EXPLORER'); ?></span></a>
</div>
<?php echo $this->shopCategoryType->displayTree('hika_categories', 0, null, true, true); ?>
</td>
<td style="vertical-align:top;" id="hika_product_main_listing">
<?php } ?>
<table class="adminlist <?php echo (HIKASHOP_BACK_RESPONSIVE)?'table table-striped table-hover':'hika_table'; ?>" style="width:100%;cell-spacing:1px">
<thead>
<tr>
<th class="title titlenum"><?php
echo JText::_('HIKA_NUM');
?></th>
<?php
$cols = 6;
$cols = 7;
<th class="title titlebox">
<input type="checkbox" name="toggle" value="" onclick="hikashop.checkAll(this);" />
</th>
<?php } ?>
<th class="hikashop_product_name_title title"><?php
echo JHTML::_('grid.sort', JText::_('HIKA_NAME'), 'a.product_name', $this->pageInfo->filter->order->dir, $this->pageInfo->filter->order->value);
?></th>
<th class="hikashop_product_code_title title"><?php
echo JHTML::_('grid.sort', JText::_('PRODUCT_CODE'), 'a.product_code', $this->pageInfo->filter->order->dir, $this->pageInfo->filter->order->value);
?></th>
<th class="hikashop_product_quantity_title title"><?php
echo JHTML::_('grid.sort', JText::_('PRODUCT_QUANTITY'), 'a.product_quantity', $this->pageInfo->filter->order->dir, $this->pageInfo->filter->order->value);
?></th>
<th class="hikashop_product_price_title title"><?php
// Price not sortable.. yet
echo JText::_('PRODUCT_PRICE');
?></th>
<th class="hikashop_product_id_title title"><?php
echo JHTML::_('grid.sort', JText::_('ID'), 'a.product_id', $this->pageInfo->filter->order->dir, $this->pageInfo->filter->order->value);
?></th>
</tr>
</thead>
<tfoot>
<tr>
<td colspan="<?php echo $cols ?>">
<?php echo $this->pagination->getListFooter(); ?>
</td>
</tr>
</tfoot>
<tbody>
<?php
$k = 0;
$i = 0;
foreach($this->rows as $product) {
$lbl1 = ''; $lbl2 = '';
$extraTr = '';
if( $this->singleSelection ) {
if($this->confirm) {
$data = '{id:'.$product->product_id;
foreach($this->elemStruct as $s) {
if($s == 'id')
continue;
$data .= ','.$s.':\''. str_replace(array('\'','"'),array('\\\'','\\\''),$product->$s).'\'';
$data .= '}';
$extraTr = ' style="cursor:pointer" onclick="window.top.hikashop.submitBox('.$data.');"';
} else {
$extraTr = ' style="cursor:pointer" onclick="hikashop_setId(\''.$product->product_id.'\');"';
if(!empty($this->pageInfo->search)) {
$row = hikashop_search($this->pageInfo->search, $product, 'product_id');
} else {
$lbl1 = '<label for="cb'.$i.'">';
$lbl2 = '</label>';
$extraTr = ' onclick="hikashop.checkRow(\'cb'.$i.'\');"';
<tr class="row<?php echo $k; ?>"<?php echo $extraTr; ?>>
<td class="hk_center"><?php
echo $this->pagination->getRowOffset($i);
?></td>
<?php if( !$this->singleSelection ) { ?>
<td class="hk_center"><input type="checkbox" onclick="this.clicked = true; this.checked = !this.checked;" value="<?php echo $product->product_id; ?>" name="cid[]" id="cb<?php echo $i; ?>"/></td>
<?php } ?>
<td class="hikashop_product_name_value"><?php
echo $product->product_name;
?></td>
<td class="hikashop_product_code_value"><?php
echo $product->product_code;
?></td>
<td class="hikashop_product_quantity_value"><?php
echo ($product->product_quantity >= 0) ? $product->product_quantity : JText::_('UNLIMITED');
?></td>
<td class="hikashop_product_price_value"><?php
if(!empty($product->prices))
echo $this->currencyHelper->displayPrices($product->prices);
?></td>
<td class="hikashop_product_id_value hk_center"><?php
?></td>
</tr>
<?php
$k = 1-$k;
$i++;
</tbody>
<?php if($this->config->get('show_category_explorer', 1)) { ?>
</table>
</td>
</tr>
hika_categories.sel(hika_categories.find(<?php echo $this->cid; ?>));
hika_categories.callbackSelection = function(tree,id) {
var d = document, node = tree.get(id);
if( node.value && node.name) {
var form = document['adminForm'];
form['cid'].value = node.value;
form.submit();
function category_listing_hideshow(el, state) {
var d = document, w = window, o = w.Oby, tree = d.getElementById("hika_categories_otree"), p = el.parentNode;
if((state !== true && o.hasClass(p, "category_explorer_btn_hide")) || state === false) {
tree.style.display = "none";
o.removeClass(p, "category_explorer_btn_hide");
o.addClass(p, "category_explorer_btn_show");
state = 0;
} else {
o.removeClass(p, "category_explorer_btn_show");
o.addClass(p, "category_explorer_btn_hide");
tree.style.display = "";
state = 1;
w.hikashop.dataStore("hikashop_product_listing_explorer", state);
return false;
(function(){
var el = document.getElementById('category_explorer_btn'),
data = window.hikashop.dataGet("hikashop_product_listing_explorer");
if(el && el.parentNode)
el.parentNode.style.height = (el.parentNode.offsetHeight) + 'px';
if(el && el.firstChild && (data == 0 || data == '0'))
category_listing_hideshow(el.firstChild, false);
</script>
<?php } ?>
</table>
<?php if( $this->singleSelection ) { ?>
<input type="hidden" name="pid" value="0" />
<?php } ?>
<input type="hidden" name="cid" value="<?php echo @$this->cid; ?>" />
<input type="hidden" name="option" value="<?php echo HIKASHOP_COMPONENT; ?>" />
<input type="hidden" name="task" value="selection" />
<input type="hidden" name="tmpl" value="component" />
<input type="hidden" name="selection" value="products" />
<input type="hidden" name="after" value="<?php echo hikaInput::get()->getVar('after', ''); ?>" />
<input type="hidden" name="afterParams" value="<?php echo hikaInput::get()->getVar('afterParams', ''); ?>" />
<input type="hidden" name="confirm" value="<?php echo $this->confirm ? '1' : '0'; ?>" />
<input type="hidden" name="single" value="<?php echo $this->singleSelection ? '1' : '0'; ?>" />
<input type="hidden" name="ctrl" value="product" />
<input type="hidden" name="boxchecked" value="0" />
<input type="hidden" name="filter_order" value="<?php echo $this->pageInfo->filter->order->value; ?>" />
<input type="hidden" name="filter_order_Dir" value="<?php echo $this->pageInfo->filter->order->dir; ?>" />
<?php
if(!empty($this->afterParams)) {
foreach($this->afterParams as $p) {
if(empty($p[0]) || !isset($p[1]))
continue;
echo '<input type="hidden" name="'.$this->escape($p[0]).'" value="'.$this->escape($p[1]).'"/>' . "\r\n";
echo '<input type="hidden" name="after" value="'.hikaInput::get()->getString('after', '').'"/>'."\r\n";
echo '<input type="hidden" name="afterParams" value="'.hikaInput::get()->getString('afterParams', '').'"/>'."\r\n";
<?php echo JHTML::_('form.token'); ?>
</form>
document.adminForm = document.getElementById("hikashop_form");
</script>
The following user(s) said Thank You: davec
Time to create page: 0.199 seconds
