Adding Products To Orders In Admin
5 years 4 months ago - 5 years 4 months ago #334611 by davec
-- Joomla version -- : 3.9.28
I have been contacted by my customer reference adding products to an order in the backend. Previously when adding a product he could see the quantity etc, but now he just has a product tree with no information. Is there a way to revert the display back to an earlier version as per the screenshot screenshot-2021.07.23-12_51_03. This is quite urgent!!
David
Last edit: 5 years 4 months ago by davec.
5 years 4 months ago #334613 by nicolas
You can edit the file product / selection.php for your backend template via the menu Display>Views.
There, remove the whole code and copy / paste this code instead :
<?php $this->listing(); $shopCategoryType = hikashop_get('type.categorysub'); $this->shopCategoryType = $shopCategoryType; if( !$this->singleSelection ) { ?> <fieldset> <div class="toolbar" id="toolbar" style="float: right;"> <button class="btn" type="button" onclick="hikashop_setId(this);"><img style="vertical-align:middle" src="<?php echo HIKASHOP_IMAGES; ?>add.png"/><?php echo JText::_('OK'); ?></button> </div> <script type="text/javascript"> function hikashop_setId(el) { if(document.hikashop_form.boxchecked.value==0){ alert('<?php echo JText::_('PLEASE_SELECT_SOMETHING', true); ?>'); }else{ el.form.ctrl.value = '<?php echo $this->ctrl ?>'; hikashop.submitform("<?php echo $this->task; ?>",el.form); } } </script> </fieldset> <?php } else { ?> <script type="text/javascript"> function hikashop_setId(id) { var form = document.getElementById("adminForm"); form.cid.value = id; form.ctrl.value = '<?php echo $this->ctrl ?>'; hikashop.submitform("<?php echo $this->task; ?>",form); } </script> <?php } ?> <form action="<?php echo hikashop_completeLink('product'); ?>" method="post" name="adminForm" id="adminForm"> <div class="hk-row-fluid"> <div class="hkc-xs-6"> <?php echo $this->loadHkLayout('search', array()); ?> </div> <div class="hkc-xs-6 hikashop_listing_filters"> <?php echo $this->productType->display('filter_product_type',$this->pageInfo->filter->filter_product_type); // // Filters // if($this->config->get('show_category_explorer', 1)) { echo $this->childDisplayType->display('filter_type', $this->pageInfo->selectedType, false, false); } ?> </div> </div> <?php if(!empty($this->breadcrumb)) { ?> <div class="hika_breadcrumb"> <?php foreach($this->breadcrumb as $i => $breadcrumb) { if($i > 0) echo '<span class="sbreadcrumb_ep">/</span> '; if($breadcrumb->category_id != $this->cid) { echo '<span class="breadcrumb_el"><a href="'.hikashop_completeLink('category&task=listing&cid='.$breadcrumb->category_id).'">'.JText::_($breadcrumb->category_name).'</a></span> '; } else { echo '<span class="breadcrumb_el">'.JText::_($breadcrumb->category_name).'</span> '; } } ?> </div> <?php } if($this->config->get('show_category_explorer', 1)) { ?> <table id="hika_product_listing" style="border:0px;width:100%"> <tr> <td style="vertical-align:top;width:1%"> <div id="category_explorer_btn" class="category_explorer_btn_hide"> <a href="#" onclick="return category_listing_hideshow(this);"><span><?php echo JText::_('EXPLORER'); ?></span></a> </div> <?php echo $this->shopCategoryType->displayTree('hika_categories', 0, null, true, true); ?> </td> <td style="vertical-align:top;" id="hika_product_main_listing"> <?php } ?> <table class="adminlist <?php echo (HIKASHOP_BACK_RESPONSIVE)?'table table-striped table-hover':'hika_table'; ?>" style="width:100%;cell-spacing:1px"> <thead> <tr> <th class="title titlenum"><?php echo JText::_('HIKA_NUM'); ?></th> <?php $cols = 6; if( !$this->singleSelection ) { $cols = 7; ?> <th class="title titlebox"> <input type="checkbox" name="toggle" value="" onclick="hikashop.checkAll(this);" /> </th> <?php } ?> <th class="hikashop_product_name_title title"><?php echo JHTML::_('grid.sort', JText::_('HIKA_NAME'), 'a.product_name', $this->pageInfo->filter->order->dir, $this->pageInfo->filter->order->value); ?></th> <th class="hikashop_product_code_title title"><?php echo JHTML::_('grid.sort', JText::_('PRODUCT_CODE'), 'a.product_code', $this->pageInfo->filter->order->dir, $this->pageInfo->filter->order->value); ?></th> <th class="hikashop_product_quantity_title title"><?php echo JHTML::_('grid.sort', JText::_('PRODUCT_QUANTITY'), 'a.product_quantity', $this->pageInfo->filter->order->dir, $this->pageInfo->filter->order->value); ?></th> <th class="hikashop_product_price_title title"><?php // Price not sortable.. yet echo JText::_('PRODUCT_PRICE'); ?></th> <th class="hikashop_product_id_title title"><?php echo JHTML::_('grid.sort', JText::_('ID'), 'a.product_id', $this->pageInfo->filter->order->dir, $this->pageInfo->filter->order->value); ?></th> </tr> </thead> <tfoot> <tr> <td colspan="<?php echo $cols ?>"> <?php echo $this->pagination->getListFooter(); ?> </td> </tr> </tfoot> <tbody> <?php $k = 0; $i = 0; foreach($this->rows as $product) { $lbl1 = ''; $lbl2 = ''; $extraTr = ''; if( $this->singleSelection ) { if($this->confirm) { $data = '{id:'.$product->product_id; foreach($this->elemStruct as $s) { if($s == 'id') continue; $data .= ','.$s.':\''. str_replace(array('\'','"'),array('\\\'','\\\''),$product->$s).'\''; } $data .= '}'; $extraTr = ' style="cursor:pointer" onclick="window.top.hikashop.submitBox('.$data.');"'; } else { $extraTr = ' style="cursor:pointer" onclick="hikashop_setId(\''.$product->product_id.'\');"'; } if(!empty($this->pageInfo->search)) { $row = hikashop_search($this->pageInfo->search, $product, 'product_id'); } } else { $lbl1 = '<label for="cb'.$i.'">'; $lbl2 = '</label>'; $extraTr = ' onclick="hikashop.checkRow(\'cb'.$i.'\');"'; } ?> <tr class="row<?php echo $k; ?>"<?php echo $extraTr; ?>> <td class="hk_center"><?php echo $this->pagination->getRowOffset($i); ?></td> <?php if( !$this->singleSelection ) { ?> <td class="hk_center"><input type="checkbox" onclick="this.clicked = true; this.checked = !this.checked;" value="<?php echo $product->product_id; ?>" name="cid[]" id="cb<?php echo $i; ?>"/></td> <?php } ?> <td class="hikashop_product_name_value"><?php echo $product->product_name; ?></td> <td class="hikashop_product_code_value"><?php echo $product->product_code; ?></td> <td class="hikashop_product_quantity_value"><?php echo ($product->product_quantity >= 0) ? $product->product_quantity : JText::_('UNLIMITED'); ?></td> <td class="hikashop_product_price_value"><?php if(!empty($product->prices)) echo $this->currencyHelper->displayPrices($product->prices); ?></td> <td class="hikashop_product_id_value hk_center"><?php echo $product->product_id; ?></td> </tr> <?php $k = 1-$k; $i++; } ?> </tbody> <?php if($this->config->get('show_category_explorer', 1)) { ?> </table> </td> </tr> <script type="text/javascript"> hika_categories.sel(hika_categories.find(<?php echo $this->cid; ?>)); hika_categories.callbackSelection = function(tree,id) { var d = document, node = tree.get(id); if( node.value && node.name) { var form = document['adminForm']; form['cid'].value = node.value; form.submit(); } }; function category_listing_hideshow(el, state) { var d = document, w = window, o = w.Oby, tree = d.getElementById("hika_categories_otree"), p = el.parentNode; if((state !== true && o.hasClass(p, "category_explorer_btn_hide")) || state === false) { tree.style.display = "none"; o.removeClass(p, "category_explorer_btn_hide"); o.addClass(p, "category_explorer_btn_show"); state = 0; } else { o.removeClass(p, "category_explorer_btn_show"); o.addClass(p, "category_explorer_btn_hide"); tree.style.display = ""; state = 1; } w.hikashop.dataStore("hikashop_product_listing_explorer", state); return false; } (function(){ var el = document.getElementById('category_explorer_btn'), data = window.hikashop.dataGet("hikashop_product_listing_explorer"); if(el && el.parentNode) el.parentNode.style.height = (el.parentNode.offsetHeight) + 'px'; if(el && el.firstChild && (data == 0 || data == '0')) category_listing_hideshow(el.firstChild, false); })(); </script> <?php } ?> </table> <?php if( $this->singleSelection ) { ?> <input type="hidden" name="pid" value="0" /> <?php } ?> <input type="hidden" name="cid" value="<?php echo @$this->cid; ?>" /> <input type="hidden" name="option" value="<?php echo HIKASHOP_COMPONENT; ?>" /> <input type="hidden" name="task" value="selection" /> <input type="hidden" name="tmpl" value="component" /> <input type="hidden" name="selection" value="products" /> <input type="hidden" name="after" value="<?php echo hikaInput::get()->getVar('after', ''); ?>" /> <input type="hidden" name="afterParams" value="<?php echo hikaInput::get()->getVar('afterParams', ''); ?>" /> <input type="hidden" name="confirm" value="<?php echo $this->confirm ? '1' : '0'; ?>" /> <input type="hidden" name="single" value="<?php echo $this->singleSelection ? '1' : '0'; ?>" /> <input type="hidden" name="ctrl" value="product" /> <input type="hidden" name="boxchecked" value="0" /> <input type="hidden" name="filter_order" value="<?php echo $this->pageInfo->filter->order->value; ?>" /> <input type="hidden" name="filter_order_Dir" value="<?php echo $this->pageInfo->filter->order->dir; ?>" /> <?php if(!empty($this->afterParams)) { foreach($this->afterParams as $p) { if(empty($p[0]) || !isset($p[1])) continue; echo '<input type="hidden" name="'.$this->escape($p[0]).'" value="'.$this->escape($p[1]).'"/>' . "\r\n"; } echo '<input type="hidden" name="after" value="'.hikaInput::get()->getString('after', '').'"/>'."\r\n"; echo '<input type="hidden" name="afterParams" value="'.hikaInput::get()->getString('afterParams', '').'"/>'."\r\n"; } ?> <?php echo JHTML::_('form.token'); ?> </form> <script type="text/javascript"> document.adminForm = document.getElementById("hikashop_form"); </script>
Then, save the view file override and you'll get back the previous interface.
The following user(s) said Thank You: davec
