Cyclic quantity of products
2 years 1 month ago #363697 by StudioPrzyLesie
Is there a configuration option to set that a customer can order e.g. only a multiple of 6 pieces of a product. Maybe there is some addition.
Tom
2 years 1 month ago #363698 by nicolas
Replied by nicolas on topic Cyclic quantity of products
You can set the minimum quantity per order to 6 in the product, and set the "quantity input" setting of the product to "show select".
This way, it will transform the quantity input field to be a dropdown with multiples of 6 like you want.
2 years 1 month ago #363702 by StudioPrzyLesie
what you write - it seems so simple that it's impossible.
GREAT!
I'll check it out!
