Problems with Discounts and also with Badges
13 years 3 months ago #118139 by drandyb
-- HikaShop version -- : 2.2.0, Business
-- Joomla version -- : 3.1.1
-- PHP version -- : 5.3.21
-- Browser(s) name and version -- : Torch version 25.0.0.3831
-- Error-message(debug-mod must be tuned on) -- : Error_message 0 SQL=INSERT IGNORE INTO `alb_hikashop_badge` ( `badge_id`,`badge_name`,`badge_published`,`badge_start`,`badge_end`,`badge_quantity`,`badge_category_id`,`badge_category_childs`,`badge_discount_id`,`badge_url`,`badge_keep_size`,`badge_size`,`badge_position`,`badge_vertical_distance`,`badge_horizontal_distance`,`badge_image` ) VALUES ( '0','10% Discuento','1','1376067240','1376153640','','2','1','2','','0','30','topright','3','3','badge2_1806584738.png' )
About 3 weeks ago I bought the business version of Hikashop (com_hikashop_business_2.2.0_2013-07-15.tar) and installed it. Since then I have been happily busy setting up all my products, etc. with no real problems - that is until today when two different issues came up.
First issue: When I began to try to set up a discount badge to use, every time I try to save the configuration of the new badge I get the following error and am taken completely out of Hikashop back to Joomla. The following is the error I receive:
Second Issue: When I tried to set up a discount and I select several products to apply the discount only one is actually applied and the only way to apply the discount to multiple products is using a category which does work but is too limited because I can´t chose which products to apply the discount to.
I will appreciate it greatly if some one can help me resolve these two issues.
13 years 3 months ago #118313 by Jerome
Please re-download and re-install HikaShop 2.2.0 in your website.
We have include a patch which will fix your "badge" table with the missing column.
After that, I recommend you to change your database drive from "mysql" to "mysqli".
We submit some fixes in the mysqli Joomla 3 driver which allow to display error messages. Unfortunately, the patch that I have submitted was not ported to the mysql driver (but mysqli is recommended for Joomla 3, more stable than the mysql one).
The discount system does not allow to select several products. You found the right solution by using a category.
What you can do is to create "hidden categories". A category which is not publish (so not visible in the front-end) but which contains some products.
A product can be in several categories so it does not create any problem.
At this moment to add or remove a product from the discount, you just have to add or remove it from the category.
13 years 3 months ago #118325 by drandyb
Jerome, thanks for the information. I have spent a lot of time setting up all my products and the website itself. I am new to this so my worry now is whether I will be able to preserve all this work or will I have to start all over with the site and products. How do I change the database drive from "mysql" to "mysqli" without losing the information in the databse or will it not be affected. Thank you for your patience with this "newbie"
13 years 3 months ago #118326 by drandyb
Also how will reinstalling Hikashop affect the products. Can I install again over the present install or do I have to uninstall frist.
13 years 3 months ago #118334 by drandyb
OK after doing some more reading I did the following: 1) updated Joomla 3.1 to version 3.1.5; 2) Set the Database type to "mysqli" ; 3) downloaded and reinstalled Hikashop 2.2.0
When I try to save my badge I get the following error:
An error has occurred.
1054 Unknown column 'badge_url' in 'field list' SQL=INSERT IGNORE INTO `alb_hikashop_badge` ( `badge_id`,`badge_name`,`badge_published`,`badge_start`,`badge_end`,`badge_quantity`,`badge_category_id`,`badge_category_childs`,`badge_discount_id`,`badge_url`,`badge_keep_size`,`badge_size`,`badge_position`,`badge_vertical_distance`,`badge_horizontal_distance`,`badge_image` ) VALUES ( '0','10% Discuento','1','','','','','0','2','','0','15','topright','5','5','badge4_394044966.png' )
message is different but still isn´t working :(
13 years 3 months ago #118351 by Jerome
You should find the HikaShop version in the HikaShop backend (in "Main > Advanced settings").
Like here : demo.hikashop.com/administrator/index.ph...config#main_advanced
Can you please give us the exact version displayed ?
I have re-check the installer of HikaShop 2.2.0 package and there is a special code which create the missing column in the badge table. That's why I tell you to re-download HikaShop 2.2.0
Otherwise you can add the column "manually" by using the SQL query (in PhpMyAdmin)
ALTER TABLE `#__hikashop_badge` ADD `badge_url` VARCHAR( 255 ) NULL DEFAULT '';
You have to replace "#_" by your database prefix. If your prefix is "jos" the table will be :"jos_hikashop_badge".
13 years 3 months ago #118367 by drandyb
Here is the exact version from the Hikashop configuration panel: HikaShop [1308100008]
I went to my Hikashop account>subscriptions and from there downloaded the business version of Hikashop 2.2.0 and reinstalled it in Joomla. I did this twice several hours apart with the same results.
13 years 3 months ago #118368 by drandyb
I am going to redownload and reinstall again now just to be absolutely sure. Maybe it will work this time.
13 years 3 months ago #118369 by drandyb
Well I just went through the routine again - downloaded, and installed then tried to create and save a badge. Get this error:
1054 Unknown column 'badge_url' in 'field list' SQL=INSERT IGNORE INTO `alb_hikashop_badge` ( `badge_id`,`badge_name`,`badge_published`,`badge_start`,`badge_end`,`badge_quantity`,`badge_category_id`,`badge_category_childs`,`badge_discount_id`,`badge_url`,`badge_keep_size`,`badge_size`,`badge_position`,`badge_vertical_distance`,`badge_horizontal_distance`,`badge_image` ) VALUES ( '0','10% Discuento','1','','','','','0','2','','0','15','topright','5','5','badge4_262562438.png' )
13 years 3 months ago #118404 by nicolas
Please run the query manually via PHPMyAdmin:
ALTER TABLE `alb_hikashop_badge` ADD `badge_url` VARCHAR( 255 ) NULL DEFAULT '';
You can run more about that issue here:
www.hikashop.com/support/documentation/6...lity-issues.html#SQL
The following user(s) said Thank You: drandyb
13 years 3 months ago #118428 by drandyb
Thanks, after running the query I can save and display badges.
