icons for product "symptomps"
11 years 10 months ago #181199 by kamakura
-- Joomla version -- : 3.3.3
Hello
is is possible to somehow implement "symptom icons" for products?
I tried to use budges, but I am not able to sort them one, near to another if there are more.
I need to add similar icons for product like it is at the attached screen.
Thank you a lot for your support
11 years 10 months ago #181243 by nicolas
Indeed, badges are close but not everything you need.
In your case, I would recommend instead to create a custom field of the table "product" and of the type "checkbox" with the column name "badge" via the menu Display>Custom fields.
Then, for each value of the field, enter a translation key like this: DF_VALUE
And then, in your translation file, add an override like this: DF_VALUE="<img src='http//mywebsite.com/df_image.png' />"
Then, in your products you can select the values you want at the bottom of the product edition page.
And finally, edit the listing_img_title file of the product view via the menu Display>Views and add such code:
<?php echo JText::_($this->row->badge); ?>
11 years 7 months ago #192580 by kamakura
Hi Nicolas
thank you very much for your imput. I did it like this. But I have one problem. I can still see just one symbol. First one. How can I do so I can see all icons?
Thank you for your support.
Kind regards
Michal
11 years 7 months ago #192586 by nicolas
I don't see why you would only see one symbol with that method.
Could you provide more information on what you did ? Screenshot of the field settings, screenshot of the product settings page, link to the products listing page ?
11 years 7 months ago #192621 by kamakura
Hi I will try to provide as much info as posible:
listing_img_title
.... <!-- VLASTNOSTI --> <div class="vlastnosti"> <?php echo JText::_($this->row->vlastnosti); ?> </div> <!-- EO VLASTNOSTI --> ...
I also tried:
<div class="vlastnosti"> <?php echo $this->element->characteristics; ?> </div>
it works as well but with same issue - just one (first) valuse is shown
Trnaslation file:
DF_GASTRO="<img src='/images/vlastnosti/gastro.png' />" DF_SK="<img src='/images/vlastnosti/SK.png' />" DF_FAIR="<img src='/images/vlastnosti/fair.png' />" DF_MLIEKO="<img src='/images/vlastnosti/mlieko.png' />" DF_CUKOR="<img src='/images/vlastnosti/cukor.png' />" DF_LEPOK="<img src='/images/vlastnosti/lepok.png' />" DF_RAW="<a href="http://bodka.azurewebsites.net/vlastnosti"><img src='/images/vlastnosti/raw.png' /></a>" DF_BIO="<img src='/images/vlastnosti/bio.png' />"
Whati is important - in backend I can see names, no pictures and I updated language file for admin part as well.
In attachment, you can see settings of the custome filed, and settings in the product itself. I can see pictore of first marked value only. so If I uncheck "BIO" I can see another picture, but still just one.
If you need any additional information or name and password so you can access page directly I can provide you.
Kind regards
Michal
11 years 7 months ago #192640 by nicolas
Ah, I see the problem.
Instead of: <?php echo JText::_($this->row->badge); ?>
use that code:
<?php foreach(explode(',',$this->row->badge) as $k){ echo JText::_($k); } ?>
11 years 7 months ago #192690 by kamakura
Great :)
thank you - it is working now :)
great support.
Time to create page: 0.671 seconds
