problem product page tab
11 years 2 months ago - 11 years 2 months ago #210786 by kaya
-- Joomla version -- : 2.5
Hi dear
In my product page I'm using hikashop tabs and tabs not work correct. When click tab content area closed tab but I want closed tab only when click tab title. My code this is:
<div id="hikashop_product_bottom_part" class="hikashop_product_bottom_part show_tabular"> <div id="hikashop_tabs_div"> <ul class="hikashop_tabs_ul"> <li id="hikashop_show_tabular_description_li" class="hikashop_tabs_li ui-corner-top"><?php echo JText::_('PRODUCT_DESCRIPTION');?></li> <?php if($hide_specs == 0){ ?> <li id="hikashop_show_tabular_specification_li" class="hikashop_tabs_li ui-corner-top"><?php echo JText::_('SPECIFICATIONS');?></li> <?php } if($status_vote == "comment" || $status_vote == "two" || $status_vote == "both" ){ ?> <li id="hikashop_show_tabular_comment_li" class="hikashop_tabs_li ui-corner-top"><?php echo JText::_('PRODUCT_COMMENT');?></li> <li id="hikashop_show_tabular_new_comment_li" class="hikashop_tabs_li ui-corner-top"><?php echo JText::_('PRODUCT_NEW_COMMENT');?></li> <?php } ?> </ul> <?php if(!empty($this->element->extraData->bottomBegin)) echo implode("\r\n",$this->element->extraData->bottomBegin); ?> <div class="hikashop_tabs_content" id="hikashop_show_tabular_description"> <div id="hikashop_product_description_main" class="hikashop_product_description_main"> <?php echo JHTML::_('content.prepare',preg_replace('#<hr *id="system-readmore" */>#i','',$this->element->product_description)); ?> </div> <span id="hikashop_product_url_main" class="hikashop_product_url_main"> <?php if (!empty ($this->element->product_url)) { echo JText :: sprintf('MANUFACTURER_URL', '<a href="' . $this->element->product_url . '" target="_blank">' . $this->element->product_url . '</a>'); } ?> </span> </div> <?php if($hide_specs == 0){ ?> <div class="hikashop_tabs_content" id="hikashop_show_tabular_specification"> <?php $this->setLayout('show_block_dimensions'); echo $this->loadTemplate(); if(!empty($this->fields)){ $this->setLayout('show_block_custom_main'); echo $this->loadTemplate(); } ?> </div> <?php } if($status_vote == "comment" || $status_vote == "two" || $status_vote == "both" ){ ?> <form action="<?php echo hikashop_currentURL() ?>" method="post" name="hikashop_comment_form" id="hikashop_comment_form"> <?php if(!empty($this->element->extraData->bottomMiddle)) echo implode("\r\n",$this->element->extraData->bottomMiddle); ?> <div class="hikashop_tabs_content" id="hikashop_show_tabular_comment"> <div id="hikashop_product_vote_listing" class="hikashop_product_vote_listing"> <?php echo $layout_vote_listing; ?> </div> </div> <div class="hikashop_tabs_content" id="hikashop_show_tabular_new_comment"> <div id="hikashop_product_vote_form" class="hikashop_product_vote_form"> <?php echo $layout_vote_form; ?> </div> </div> </form> <?php } ?> <input type="hidden" name="selected_tab" id="selected_tab" value="hikashop_show_tabular_description"/> <?php if(!empty($this->element->extraData->bottomEnd)) echo implode("\r\n",$this->element->extraData->bottomEnd); ?> </div> </div> <script type="text/javascript"> if(typeof(hkjQuery) == "undefined") window.hkjQuery = window.jQuery; window.hikashop.ready( function(){ var selectedTab = hkjQuery( "#selected_tab" ).val(); hkjQuery("#hikashop_tabs_div").children("div").css("display","none"); hkjQuery( "#"+selectedTab+"_li" ).addClass("hikashop_tabs_li_selected"); hkjQuery("#"+selectedTab).css("display","inherit"); hkjQuery( "#hikashop_tabs_div" ).children().children().click(function(){ var currentLi = hkjQuery(this).attr("id"); var currentDiv = currentLi.replace("_li",""); hkjQuery("#hikashop_tabs_div").children("div").css("display","none"); hkjQuery("#hikashop_tabs_div").children("form").children("div").css("display","none"); hkjQuery("#"+currentDiv).css("display","inherit"); hkjQuery( ".hikashop_tabs_li_selected" ).removeClass("hikashop_tabs_li_selected"); hkjQuery( "#"+currentLi ).addClass("hikashop_tabs_li_selected"); }); }); </script>
What is my problem?
thank you.
Last edit: 11 years 2 months ago by kaya.
11 years 2 months ago #210789 by nicolas
Replied by nicolas on topic problem product page tab
Please provide a link to the page with the issue so that we can analyze the problem.
The following user(s) said Thank You: kaya
11 years 2 months ago #210862 by kaya
Replied by kaya on topic problem product page tab
Thank you dear nicolas
I send to you my link in a private message.
11 years 2 months ago #210875 by nicolas
I don't see any problems with the tabs on your link.
When I arrive on it, I see this:
take.ms/CdHiN
Then, if I click on the other tab, I get this:
take.ms/wfFBA
So the tabs look normal to me.
11 years 2 months ago - 11 years 1 month ago #210964 by kaya
My tabs work but problem in tab content area if you click in tab content area closed tab and it's my problem.
Last edit: 11 years 1 month ago by kaya.
11 years 1 month ago #210977 by Jerome
Replied by Jerome on topic problem product page tab
Please edit the view "product / show_tabular" and replace the line
By
hkjQuery("#hikashop_tabs_div .hikashop_tabs_ul li").click(function(){
It should fix your issue.
11 years 1 month ago - 11 years 1 month ago #211001 by kaya
Hi dear Jerome
Thank you it's work now.
Time to create page: 0.185 seconds
