Products only display in one column after Hikashop Business upgrade
9 years 5 months ago #271225 by LAMF
-- url of the page with the problem -- : www.dsgbutiken.com/index.php/tillbehor-bil-lastbil/olja-filter
-- Joomla version -- : 3.7.2
-- PHP version -- : 7.0.15
-- Browser(s) name and version -- : Anyone
After upgrading to HS Business 3.1.1 my products display only in one column.
No changes made, I have it set for 4 column display but that doesn't work anymore.
Please someone advice how to get the 4 column layout back.
Thanks,
Micke
9 years 4 months ago #271923 by jgribble
This is obviously a common problem. Thanks for the quick reply. The other threads only vaguely inform my particular issue. I wondered if you could possibly take a glance here? roguesailing.org:8080/index.php/all-products
You will probably know almost instantly what's causing the problem. I can fix any code or script if pointed in the right direction. Your help is always appreciated.
-Jim Gribble
9 years 4 months ago #271924 by jgribble
Jerome, I hunted it down in the old.css file. Thanks for the clue.
-Jim Gribble
9 years 4 months ago #271925 by jgribble
frontend_old.css, line 46, to be exact, for anybody else looking for it.
-Jim Gribble
9 years 4 months ago #271927 by jgribble
This solved a big problem, but not entirely. In div layout, rows display unevenly. Some show two products and a gap where the third should be. It is not an issue with the individual products because I experimented with unpublishing the ones in the vicinity of the "gaps." This is a new one, and I wasn't even sure what to type into the search window. I am attaching screen shot by way of explanation.
-Jim Gribble
9 years 4 months ago #271928 by jgribble
When I toggle to use default.css, the issue goes away, but the products don't look as nice. Still fiddling.
9 years 4 months ago #271945 by nicolas
That comes from the fact that the product boxes aren't all the same height on your listing with the old CSS you're using.
You can just force the height of the boxes to avoid the problem.
For example, by adding such CSS:
.hikashop_subcontainer{ height: 300px; }
9 years 4 months ago #271982 by jgribble
Thanks I did kind of figure this out on my own. Why though would I even want to use the old css instead of the default? When I switched to the default everything worked better. I certainly am seeing the virtue of the custom.css system for fine-tuning the view.
-Jim Gribble
9 years 4 months ago #271987 by nicolas
It's indeed better to use the default CSS. Also, if you need to add custom CSS, it's better to add it on your template, and not in HikaShop. That way, when you update HikaShop you keep getting all the new CSS we add for the new features.
9 years 4 months ago #272033 by jgribble
Thanks for the tip. I generally do as your suggesting and keep a log of all edits. This is a good nuance for everybody to know, especially those of us who do highly designed sites in which all the elements have to have a visual harmony.
-Jim G.
