How is it possible to view individual product page as a module
9 years 2 months ago #278181 by Vitko
-- Joomla version -- : 3.7.5
-- PHP version -- : 7.0.23
-- Browser(s) name and version -- : Safari
Hi support team,
I would like to ask, how is it possible to view individual product page as a module.
Example this page: biliner.co.uk/index.php/biliner-shop/pro...lass-1000-ml-plastic
Many many thank you :-)
Pavel
9 years 2 months ago #278185 by Jerome
I'm sorry but I don't understand your example.
About your question ; thanks to custom module and development, you can display whatever you want.
But no, there is no HikaShop module to display a product page since a product page is something big that you do not want to display within a module.
You can use the "product insert tag" at least ; but the full product page could be a bit much (specially if you got characteristics or custom fields).
9 years 2 months ago #278272 by Vitko
Hi Jerome,
I apologize for the wrong explanation. I would like to display the product detail page as a module. I tried to use Custom module but unfortunately I do not get the product detail page to display. I need to show two product details side by side. For example, here (see image) or
Link:https://www.hildon.com/buy/online/
If that's understandable, is there any chance you can advise me somehow?
Many thanks,
Pavel
9 years 2 months ago #278287 by nicolas
You can use this extension extensions.joomla.org/profile/extension/...components-anywhere/ in a custom HTML module to do that. Just make sure that you add the parameter ?tmpl=component to the URL of the product page so that it removes the template and the modules around it to only get the product page inner content when that extension replaces the tag.
