How to combine product variants with custom field
9 years 1 month ago #279415 by woidl
-- Joomla version -- : 3.8
-- PHP version -- : 7
I made a custom field (text area) to be shown beside the product.
The customer is now able to fill in his personal text for a greeting-card message.
This greeting card costs an additional amount of 5 Euro.
Problem:
The text area is always there and customers can always fill in a text - even if the choose "NO, thank you" to the greeting card.
Is it possible to make the the custom field depending to the choice of the user ( greeting card yes or no)?
Maybe just visible when the choice is YES? Or just editable when chosen YES?
Screenshots:
one product with variants plus custom field
one product plus second product (greeting card) options
9 years 1 month ago #279441 by nicolas
There is no option for that.
That would require adding some custom javascript on the product page in order to hide/display the field based on the characteristic selection.
An alternative is to duplicate the product, one for the card without message, and one for the card with the message.
Or, you could also do it like that, without any coding:
Don't use a characteristic. Have instead a custom item field with its column name being "amount" configured as a simple dropdown with two values, and in each value set the title to what you want to display as choice on the dropdown and as value the amount you want to charge. Then, in your text custom field, use the "display limited to" setting to only display it for one of the two values of your new custom item field.
Finally, configure the donation plugin of HikaShop: demo.hikashop.com/index.php/en/hikashop/...t-page/donation-page
That way, it will take the value selected in the dropdown by the customer as price for the product once in the cart.
9 years 1 month ago #279529 by woidl
thanks for this very clever solution.
Unfortunately I am already using the custom field with the table name "amount" for another purpose (fill in the amount for gift vouchers).
So I cannot save another custom field with "amount".
Duplicating products is the only solution without coding?
9 years 1 month ago #279548 by nicolas
You could create another custom field, and make a copy of the donation plugin, changing its name and the field name in it so that you could have both running in parallel. However, without any coding knowledge, it will be difficult. But it will be easy for anyone knowing even a bit of coding. So you could ask our partners: www.hikashop.com/home/our-partners.html
They should be able to do that for you for a small price.
8 years 10 months ago #284995 by justme
nicolas wrote: Hi,
I have done what you suggest here and this is exactly the sollution to our problem. The only last problem is that this plugin changes the total price and not adds the amount in the selected field (from the donation plugin). Is it possible to alter the code so it adds the selected amount to the amount in the cart and not change the total amount? I guess I have to change this code:
$currencyClass->quantityPrices($product->prices,$quantity,$product->cart_product_total_quantity);
But I don't know how.
Thank you in advance,
8 years 10 months ago #284999 by nicolas
No, this plugin doesn't replace the total.
What this plugin does is that it uses the value entered in the custom field of that product as the unit price of that product.
If you increase the quantity of that product, or if you add other products, the total will take these into account.
If you mean that you want that the value entered in the custom field of that product is added to the unit price of that product the you need to change all the place where you have the code:
hikashop_toFloat($product->$column)
hikashop_toFloat($product->$column+$product->prices[$k]->price_value)
or
hikashop_toFloat($product->$column+$product->prices[$k]->price_value_with_tax)
The following user(s) said Thank You: justme
8 years 10 months ago #285523 by justme
A late response because I have been very sick. But I finally feel well enough to look at this again.
Thank you so much for this! You are great! This is exactly what I need.
8 years 10 months ago #285524 by justme
For everyone else looking for adding a custom item field with a price to go on top of the price of the product. Do as Nicolas explained and change the donation plugin located in plugins/system/custom_price. Below is the code for custom_price.php
<?php /** * @package HikaShop for Joomla! * @version 2.6.4 * @author hikashop.com * @copyright (C) 2010-2016 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); ?><?php jimport('joomla.plugin.plugin'); class plgSystemCustom_price extends JPlugin{ } if(!function_exists('hikashop_product_price_for_quantity_in_cart') && !function_exists('hikashop_product_price_for_quantity_in_order')) { function hikashop_product_price_for_quantity_in_cart(&$product){ $currencyClass = hikashop_get('class.currency'); $quantity = @$product->cart_product_quantity; $plugin = JPluginHelper::getPlugin('system', 'custom_price'); if(version_compare(JVERSION,'2.5','<')){ jimport('joomla.html.parameter'); $params = new JParameter($plugin->params); } else { $params = new JRegistry($plugin->params); } $taxes = $params->get('taxes',0); $column = $params->get('field','amount'); if(!empty($product->$column)){ if(empty($product->prices)){ $price= new stdClass(); $price->price_currency_id = hikashop_getCurrency(); $price->price_min_quantity = 1; $product->prices = array($price); } foreach($product->prices as $k => $price){ if($taxes && $product->product_type=='variant' && empty($product->product_tax_id)){ $productClass = hikashop_get('class.product'); $main = $productClass->get($product->product_parent_id); $product->product_tax_id = $main->product_tax_id; } switch($taxes){ case 2: $product->prices[$k]->price_value = $currencyClass->getUntaxedPrice(hikashop_toFloat($product->$column+$product->prices[$k]->price_value_with_tax),hikashop_getZone(),$product->product_tax_id); $product->prices[$k]->taxes=$currencyClass->taxRates; $product->prices[$k]->price_value_with_tax = hikashop_toFloat($product->$column+$product->prices[$k]->price_value_with_tax); break; case 1: $product->prices[$k]->price_value = hikashop_toFloat($product->$column+$product->prices[$k]->price_value_with_tax); $product->prices[$k]->price_value_with_tax = $currencyClass->getTaxedPrice(hikashop_toFloat($product->$column+$product->prices[$k]->price_value_with_tax),hikashop_getZone(),$product->product_tax_id); $product->prices[$k]->taxes=$currencyClass->taxRates; break; case 0: default: $product->prices[$k]->price_value = hikashop_toFloat($product->$column+$product->prices[$k]->price_value_with_tax); $product->prices[$k]->price_value_with_tax = hikashop_toFloat($product->$column+$product->prices[$k]->price_value_with_tax); break; } } } $currencyClass->quantityPrices($product->prices,$quantity,$product->cart_product_total_quantity); } }
