- Thank you received: 5
Displaying products from specific custom field
8 years 10 months ago #282509
by ltempest
Displaying products from specific custom field was created by ltempest
thhs.under-development.info/
-- Joomla version -- : 3.8.2
I have created a custom field within the products table. This will either be a 1 or 0 value entered.
I then have a HikaShop content module set to display the products ordered on that field. I have limited the display to only 10 products but more than this have been assigned the 1 value in the custom field.
Is it possible to randomly select and display those products that have been assigned the 1 value in the custom field?
When I choose random items as Yes it does not display only those products with the 1 value but random products from across all my categories.
8 years 10 months ago #282512
Replied by nicolas on topic Displaying products from specific custom field
With the random option turned off and the ordering direction in descending order, you'll get the products with 1 in that field before the products with 0 so that's a way of filtering.
But then, you can't have them display randomly.
If you configure a menu item instead of a module, with filters, it's possible to force such rule thanks to parameters in the URL.
For for a module, it's not possible to do that as filters only apply to menu items.
The last option is to develop a small hikashop plugin implementing the onBeforeProductListingLoad trigger to add your extra condition on that custom field when you want it:
www.hikashop.com/support/documentation/6...reProductListingLoad
8 years 10 months ago #282829
by ltempest
Replied by ltempest on topic Displaying products from specific custom field
Nicolas,
Thanks for the reply, most appreciated. I'm testing with a menu and cannot get it to display only the products with 1 in the custom field.
Could you advise on the menu options I need?
Lee
Lee
8 years 10 months ago #282831
You need to set the "sub element filter" setting to "all sub elements". Otherwise, it will only take into account the products directly linked to the category "product category" and not the products linked to sub categories of that category.
Time to create page: 0.194 seconds
