Not showing Brands
7 years 3 months ago #309318 by Crashbandi
-- url of the page with the problem -- : www.luxminime.com/index.php/en/girls
-- HikaShop version -- : 4.2.1
-- Joomla version -- : 3.9.10
-- PHP version -- : 7.2.19
I have configured Hikashop to display the brand, but it is not showing. 'Display the btrand' is set to 'Yes' and the menu setting is 'Inherit'.
Colin.
7 years 3 months ago #309321 by nicolas
Replied by nicolas on topic Not showing Brands
It seems that your product details page layout is customized.
So I suspect that the customization doesn't display the brand area.
Check the folder templates/YOUR_TEMPLATE/html/com_hikashop/product/ via FTP.
There, you'll find several view file overrides. Try renaming them one by one to deactivate them and see if it helps until you find the file which customize that part and prevent the brand from being displayed.
Then, you can contact either your template provider or the person who customized the layout for you to ask them to look into it.
7 years 3 months ago #309419 by Crashbandi
Replied by Crashbandi on topic Not showing Brands
I renamed each of the 6 files and it made no difference.
I contacted the template provider and they say it must be somehow disabled.
My Hikkashop configuration is: Display/Product Options/Display the brand = Yes
Hope you can help.
Colin
7 years 3 months ago #309420 by Crashbandi
Here is the image they sent me.
7 years 2 months ago #309428 by nicolas
Well, from what I can understand it should come from the file templates/YOUR_TEMPLATE/html/com_hikashop/product/show_tabular.php which modifies the tabs system incorrectly.
What you can do is to add such CSS on your website to prevent that:
#hikashop_show_tabular_specification{ display:block !important; }
7 years 2 months ago #309435 by Crashbandi
Thanks Nicolas, the css worked.
It displays the brand near the bottom of the page. Could you let me know how to display near the top, just above the SKU?
Thanks again,
Colin.
7 years 2 months ago #309462 by Mohamed Thelji
Replied by Mohamed Thelji on topic Not showing Brands
Hello Colin,
Can you show us more screenshots of what you have and of how you want it to be displayed ? Thank you.
You'll probably have to directly edit the code of the "show_default" file via "Hikashop->Display->Views".
Kind regards,
Mohamed Thelji.
7 years 2 months ago #309472 by Crashbandi
For info an example is HERE
I have attached a screenshot.
'A' is the current view with the Brand at the bottom of the page.
'B' is how I would like it to look with the brand just above the SKU.
Colin.
7 years 2 months ago #309476 by Mohamed Thelji
In that case the solution will be to directly edit the "show_default" file of the "product" view of your front-end template via "Hikashop->Display->Views", and move that code where you want it to be displayed :
<span id="hikashop_product_url_main" class="hikashop_product_url_main"><?php if(!empty($this->element->product_url)) { // DISPLAY the manufacturer echo JText::sprintf('MANUFACTURER_URL', '<a href="' . $this->element->product_url . '" target="_blank">' . $this->element->product_url . '</a>'); } ?> </span>
7 years 2 months ago #309497 by Crashbandi
I found similar code and moved it, but it made no difference?
Here is my code:
?></span>
Colin.
7 years 2 months ago #309499 by Mohamed Thelji
Hello Colin,
In that case you're probably editing the file of the wrong front-end template via "Hikashop->Display->Views".
Kind regards,
Mohamed Thelji.
7 years 2 months ago #309538 by Crashbandi
This is the file I am editing:
Colin.
7 years 2 months ago #309545 by Mohamed Thelji
Hello Colin,
You can eventually send us a temporary back-end access through our contact form so that we can directly check why you can't apply your modification (please don't forget to add a link to that thread in your message) :
Kind regards,
Mohamed Thelji
7 years 2 months ago #309581 by Crashbandi
I have sent the info.
Colin.
7 years 2 months ago #309585 by Mohamed Thelji
My bad I mistook the brand url and the manufacturer url.
The modification was added through the "Show_tabular" file of the "Product" view of our front-end template.
Kind regards,
Mohamed Thelji.
7 years 2 months ago - 7 years 2 months ago #309607 by Crashbandi
That's great.
Thank you for your help with this.
I can't see the code in the JD Shop template. Am I looking at the right file?
Also, I have removed the word 'Brand' via Joomla Language Overrides, but I can't remove the colon ':'?
Colin.
Last edit: 7 years 2 months ago by Crashbandi.
7 years 2 months ago #309627 by Mohamed Thelji
Hello Colin,
We had to edit the "Show_tabular" file of the "product" view of your front-end template via "Hikashop->Display->Views" and move that code :
if(isset($specif_tab_content)) echo $specif_tab_content.'</br>';
So you'll have to edit the $specif_tab_content variable.
We wish you a nice day,
Kind regards,
Mohamed Thelji.
7 years 2 months ago #309640 by Crashbandi
OK, thanks.
Colin.
7 years 2 months ago #310011 by Crashbandi
Just a quick one. Where can I delete the colon just before the brand name. As shown in the attachment.
Colin.
7 years 2 months ago #310014 by nicolas
Normally, it's from the line:
echo JText::_('MANUFACTURER').': '.'<a href="'.hikashop_contentLink('category&task=listing&cid='.$manufacturer->category_id.'&name='.$manufacturer->alias.'&Itemid='.$Itemid,$manufacturer).'">'.$manufacturer->category_name.'</a>';
in show_block_dimensions.php
However, as your product page layout is customized, it might be in another file of the product view.
