Column Width problem
6 years 11 months ago - 6 years 11 months ago #311916 by Formidog
-- url of the page with the problem -- : formidogrijswijk.nl/vers
-- HikaShop version -- : 4.2.1 business
-- Joomla version -- : 3.9.12
Good morning
After updating the Hikashop component to 4.2.1 (business) I have a column problem on the category pages.
The left column, with the filters, breaks into the main area.
Where can I repair this?
Thanks in advance,
Dick
Last edit: 6 years 11 months ago by Formidog.
6 years 11 months ago - 6 years 11 months ago #311918 by SchmidtSon
Replied by SchmidtSon on topic Column Width problem
Hi try this for the Column width:
Go into ure hikashop.css in Folder: media/com_hikashop/css/hikashop.css on line 1237 and set this
.hikashop_filter_fieldset { display: inline-block; }
to this
.hikashop_filter_fieldset { display: block; }
after this go to ure custom.css of hikashop and write this:
#slider_Size_3_hikashop_category_information_menu_138 { display:inline-block!important; width:100%!important; }
best regards from Germany ;-)
Last edit: 6 years 11 months ago by SchmidtSon.
6 years 11 months ago #311934 by nicolas
Replied by nicolas on topic Column Width problem
Please don't edit directly hikashop.css as it will be overwritten after each update of HikaShop.
If you want to change that CSS code, it's better to add such CSS to your custom CSS file:
.hikashop_filter_fieldset { display: block !important; }
6 years 11 months ago #311967 by SchmidtSon
nicolas wrote: Hi,
Yes that´s true,
my mistake, sry i had the same Problem, after this i only write into the custom.css ...
Best regards
Time to create page: 0.151 seconds
