- Thank you received: 6
Column Width problem
7 years 1 month ago - 7 years 1 month ago #311916
by Formidog
Column Width problem was created by Formidog
formidogrijswijk.nl/vers
-- HikaShop version -- : 4.2.1 business
-- Joomla version -- : 3.9.12
Good morning
After updating the Hikashop component to 4.2.1 (business) I have a column problem on the category pages.
The left column, with the filters, breaks into the main area.
Where can I repair this?
Thanks in advance,
Dick
Good morning
Thanks in advance,
Dick
Last edit: 7 years 1 month ago by Formidog.
7 years 1 month ago - 7 years 1 month ago #311918
by SchmidtSon
Replied by SchmidtSon on topic Column Width problem
Hi try this for the Column width:
Go into ure hikashop.css in Folder: media/com_hikashop/css/hikashop.css on line 1237 and set this
to this
after this go to ure custom.css of hikashop and write this:
best regards from Germany
.hikashop_filter_fieldset {
display: inline-block;
display: block;
#slider_Size_3_hikashop_category_information_menu_138 {
display:inline-block!important;
width:100%!important;
Last edit: 7 years 1 month ago by SchmidtSon.
7 years 1 month ago #311934
Replied by nicolas on topic Column Width problem
Please don't edit directly hikashop.css as it will be overwritten after each update of HikaShop.
If you want to change that CSS code, it's better to add such CSS to your custom CSS file:
display: block !important;
7 years 1 month ago #311967
by SchmidtSon
Yes that´s true,
my mistake, sry i had the same Problem, after this i only write into the custom.css ...
Best regards
nicolas wrote: Hi,
If you want to change that CSS code, it's better to add such CSS to your custom CSS file:Code:.hikashop_filter_fieldset { display: block !important; }
Yes that´s true,
Best regards
