Hidden Variant Causing Issues
6 years 1 month ago #323426 by MyWorld
Just checking in regarding my last post :)
Thanks!
6 years 4 weeks ago - 6 years 4 weeks ago #323531 by Philip
You have just to reproduce the same configuration from "Snap Buttons" characteristic, but with your"default" characteristic, and the important point is to switch it on the second characteristics
regards
Last edit: 6 years 4 weeks ago by Philip.
6 years 4 weeks ago #323586 by MyWorld
How do I remove the Characteristics from the product name, as per the attached. It should not be there.
Thanks!
6 years 3 weeks ago - 6 years 3 weeks ago #323695 by Philip
We can suggest to give name to your variant like this example :
That will leads to see result :
See it by yourself on your product frontend & backend.
Last edit: 6 years 3 weeks ago by Philip.
6 years 3 weeks ago #323717 by MyWorld
Hi Philip,
In order to do what you suggested, I would have to go through ALL the products and rename the variants - that is too much :(
Is it possible that I can add a class around the characteristic so that I can hide it? That would make things much easier/faster.
If not, I will just hope that in the near future the "Characteristics dynamic display" will not work ONLY when you have more than 1 characteristics.
www.hikashop.com/support/forum/product-c...g-issues.html#322784
Thanks!
6 years 3 weeks ago - 6 years 3 weeks ago #323736 by Philip
Yes, you can use a custom css code to remove the "extra" variant name, with this kind of code :
span.hikashop_product_variant_subname { display: none; }
If you use this, as a result on any page the variant subname won't be display anymore.
If you want only remove it on a specific context, you can process like this :
div.specific_html_page_class span.hikashop_product_variant_subname { display: none; }
Hope this will fit your needs.
Time to create page: 0.178 seconds
