Bundle products
1 year 7 months ago - 1 year 7 months ago #365626 by Rusty
Bundle products was created by Rusty
Hi!
I have tested your demo shop. In the backend -> product I had some problems. I edited the product ‘MacBook_Pro’ and tried to add two products as a bundle. But in the frontend I could not find any result. Maybe this is a bug?
Last edit: 1 year 7 months ago by Rusty.
1 year 7 months ago #365627 by nicolas
Replied by nicolas on topic Bundle products
It is not a bug.
The goal of the bundle feature is to be able to take into account the stock of the bundled products automatically.
For example, if you have a stock of 2 for a product added as a bundle to the main product with an unlimited stock. That main product will have a stock of 2. And if that main product is purchased, the stock of the bundled product will be decremented.
Usually, you don't really want to do other things with bundles. For example, for price, you usually want to set a special price for the bundle, not just the sum of the separate products. And you also don't necessarily want the name of the bundled products to be included on the product page, but have a more customized explanation directly in the description of the bundle product.
The following user(s) said Thank You: Rusty
Time to create page: 0.149 seconds
