Ignore Warehouse when using shipping method
10 years 10 months ago #222200 by grayt7
There are a number of warehouses setup with products in each. I have setup 1 shipping method with a simple restriction of UK only and under 1Kg, cost is £5.
If a customer selects products from multiple warehouses the shipping method is applied to each warehouse. However, I don't want this, I would like the shipping method to be applied once for the cart.If there are 3 warehouses the price of shipping ends up being £15!
I do understand the need to have specific shipping rules for each warehouse, but this doesn't work in all instances?
10 years 10 months ago #222228 by Mohamed Thelji
If you don't plan to use one shipping method per warehouse, using warehouses in your product won't be necessary, so the best solution will be to :
- Remove warehouses from your products
or
- Create one shipping method per warehouse.
10 years 10 months ago #222296 by grayt7
HI,
Thanks for getting back to me. Unfortunately we are using the warehouse to customize email output so moving the products into one warehouse is not possible. Also its not logical as the client does in fact use multiple warehouses but one shipping method.
Is there any customisation that can be done so that the shipping methods do not separate per warehouse? Seems logical that there should be an option not to split shipping per warehouse?
Many thanks!
10 years 10 months ago #222310 by Jerome
No.
The main and only goal of the warehouses is to split the products in different groups for the shipping.
10 years 10 months ago - 10 years 10 months ago #222432 by grayt7
OK thanks for letting me know.
This seems very limiting. The warehouse section needs to be expanded with more functionality.
examples could be.
  • attributing more information per warehouse
  • shipping emails that can be sent directly to each warehouse, so that the warehouse can deal with the shipping of goods
  • ability for shipping method to ignore the split per warehouse and provide over all shipping cost
  • manage stock based on warehouse
many thanks.
Last edit: 10 years 10 months ago by grayt7.
10 years 10 months ago #222441 by Mohamed Thelji
Thanks for your feedback, we'll add it on our todo list.
Time to create page: 0.180 seconds
