Discount codes and multiple tax rates
12 years 1 month ago #175204
by yannickv
Discount codes and multiple tax rates was created by yannickv
www.kvcv.be
-- Joomla version -- : 2.5.27
-- PHP version -- : 5.4.30
-- Browser(s) name and version -- : Chrome 37
On our webshop we have discount codes and will now introduces multiple tax rates (default 21%, reduced tax of 6% for books). I just can't figure out how to implement the discount codes in combination with the different tax rates.
I'm using these settings:
* Apply discounts: before taxes
* Product tax category set for coupon code: none
Now the problem is that on the cart confirmation page, some numbers are not right. The discount is calculated correctly from the total amount (excl. TAX). But for every TAX category, the subtotal is reduced by the full reduction, instead of reducing each amount by the discount of 20%. As a result, the displayed TAX amounts for 6% and 21% are wrong.
What I want to achieve is:
* get a reduction of 20% for each subtotal for each tax category
* calculate the VAT based on this reduced number
* sum these numbers up to make the total
12 years 1 month ago #175207
Replied by nicolas on topic Discount codes and multiple tax rates
So from what I understand your discount is actually a coupon type not a discount type.
There is no system at the moment in HikaShop to apply the coupon to both tax compounds at the same time. You can select a tax category in the coupon so that it applies to one of them, but not to both.
What I would recommend in your case is to contact AWOCoupon Pro ( awodev.com/products/joomla/awocoupon ), which integrates with HikaShop to provide a more advanced coupon system and ask them if their system can support compounded taxes.
12 years 1 month ago #175264
by yannickv
Replied by yannickv on topic Discount codes and multiple tax rates
Thanks for your feedback.
Indeed I'm using coupons, sorry for the confusion.
I will contact AWOCoupon Pro to check whether that fits our needs.
