-- Joomla version -- : 3.8.3
-- Browser(s) name and version -- : Google chrome
-- Error-message(debug-mod must be tuned on) -- : Can't filter product from subcategorys
I created a filter, using characteristics, and i'm using Hikashop Filter Module to display the filter.
If i go to a sub-category that has product and on that category i use the filter, everything it is ok, the filter is working.
But if i try to use the filter from the parent category, the filter does not find anything.
Use Dropdown filter and select JPG to test the filter.
I'm talking about the module from left side on my site.
If you go to this url, you will see the filter working:
Here is not working anymore :
And also is not working in homepage
