1. That's because of the CSS and the layout of your template and the custom CSS you added.
Here is the CSS you can add to fix that:
.hikashop_product_top_part {
height: 100px !important;
.hikashop_product_left_part {
width: 350px !important;
.hikashop_product_right_part {
width: 200px !important;
2. That's indeed a bug in the correct version. Edit the file "form" of the view "vote" via the menu Display>Views and change the lines:
<input type="hidden" name="vote_type" id="vote_type" value="<?php echo $type_item; ?>"/>
<input type="hidden" name="hikashop_vote_user_id" id="hikashop_vote_user_id" value="<?php echo $hikashop_vote_user_id;?>"/>
<input type="hidden" name="hikashop_vote_ok" id="hikashop_vote_ok" value="0"/>
<input type="hidden" name="vote_type" id="vote_type_<?php echo $hikashop_vote_ref_id;?>" value="<?php echo $type_item; ?>"/>
<input type="hidden" name="hikashop_vote_user_id" id="hikashop_vote_user_id_<?php echo $hikashop_vote_ref_id;?>" value="<?php echo $hikashop_vote_user_id;?>"/>
<input type="hidden" name="hikashop_vote_ok" id="hikashop_vote_ok_<?php echo $hikashop_vote_ref_id;?>" value="0"/>
and that should fix the problem.
3. The filter feature is indeed only available in the Business edition:
www.hikashop.com/support/documentation/1...-filter-listing.html
