Tags joomla System
12 years 4 months ago #156418
Hi I have a doubt about the joomla system tags added to the new version.
I need to first create the tags in the native joomla component?
I have 2 questions:
1 - How to make labels created in the product screen display?
2 - These tags link to product listings?
Thank you.
I think it would be a good feature to add the labels from the HikaShop itself.
12 years 4 months ago #156439
Simply write the text you want in the Tags selection input and it will create a new tag when you press enter. No need to pre create them.
The tags on the product page link to the tags listing page of Joomla, which will indeed display other products with the same tags.
12 years 1 month ago #166783
Hikashop should create a tag system like the one the Zoo component from youtheme has. This is a very good system and give you a lot of SEO traffic to your online store.
12 years 1 month ago #166804
As far as I can see, you can do the same thing with the Joomla tags and the Zoo tags. What is better in them ? Could you give more infos ?
12 years 4 weeks ago #168375
I want to display joomla tags on the product detail page but they dont show. I can t find anywhere in the config where they are enabled or disabled.
D
  • Thank you received: 4078
12 years 4 weeks ago #168420
There is no implementation (so no option) to display the Joomla tags in the HikaShop product page.
But you can already add it in the HikaShop views (using an override) thanks to some PHP code.
The development is in our TODO list with the rest of the improvements for the product pages.
You can read the documentation on Joomla tags with extensions (sections "Prepare the view" and "Set up the display")
docs.joomla.org/J3.x:Using_Tags_in_an_Extension
12 years 4 weeks ago #168531
Ok thanks. I will look forward to that update :-) In the emanative Ill see about that override. Good code practice!
11 years 10 months ago #176608
Jerome wrote: Hi,
so - trying to follow the Joomla docs, I added this
$item->tags = new JHelperTags;
 $item->tags->getItemTags('com_hikashop.product.' , $this->item->id);
to the top of components/com_hikashop/views/product/view.html.php
"com_hikashop.product" (not "products") is found in the types joomla content table
I then played with this is in...
product/show_default.php
as an ovveride in my template
by adding
<?php $this->item->tagLayout = new JLayoutFile('joomla.content.tags'); ?>
<?php echo $this->item->tagLayout->render($this->item->tags->itemTags); ?>
in an area that was currently being rendered on a page
but no tags from that item were displayed.
What is my failure in logic?
11 years 10 months ago #176652
Good news, the Joomla tags are now available in HikaShop.
In the product edition page, under the description area you will be able to see a field "Tags".
Just fill the desired tags here ;)
If you don't see this field, please update.
11 years 10 months ago #176721
in "Default parameters for products" in the main configuration, there is no option to show / hide tags
so wondering where the option is to show or not show tags when in the product view?
PS the field to add tags to the product was already working in the version I had (but just updated anyway)
what seems to be missing is the ability to show these tags with the product when it is displayed.
Last edit: 11 years 10 months ago by netpastor.
11 years 10 months ago #176800
You can put that code in the product page (show_default).
$tagHelper = hikashop_get('helper.tags');
if($tagHelper->isCompatible()) {
	$this->element->tags = new JHelperTags;
	$this->element->tags->getItemTags('com_hikashop.product', $this->element->product_id);
	if($this->params->get('show_tags', 1) && !empty($this->element->tags)) {
		$this->element->tagLayout = new JLayoutFile('joomla.content.tags');
		<div id="hikashop_product_tags_main" class="hikashop_product_tags"><?php
			echo $this->element->tagLayout->render($this->element->tags->itemTags);
		?></div>
<?php
11 years 10 months ago #176981
Thanks Jerome
works a treat
One thing I think is missing from documentation is a clear outline / chart of what each override is for
ie I think hika has done well in using well placed words to describe the override, but often it is still not obvious
thus a clear flow chart of where each override is placed in the overall heirarchy would be helpful to the end-user / developer.
But maybe it already exists, and I can't find it :-)
11 years 10 months ago #176987
11 years 10 months ago #177115
nicolas wrote: Hi,
You can find that here:
www.hikashop.com/support/support/documen...-display.html#layout
Thanks Nicolas - I was probably thinking of something a little more intuitive, but I get the syntax :-)
  • Thank you received: 74
11 years 10 months ago #178549
with the last version
$this->setLayout('show_block_tags');
echo $this->loadTemplate();
works perfectly but where does it get these class ?
<div class="tags">
<span class="tag-2 tag-list0" itemprop="keywords">
<a href="" class="label label-info">
I dont find it in any joomla tag view component or module
thank you
11 years 10 months ago #178552
It's Joomla related, not HikaShop related.
See the Joomla layouts (joomla/content/tags)
The following user(s) said Thank You: erickb
10 years 10 months ago #219025
So either I need more coffee or I am not understanding this. I do not want tags to show on the product main page. How do I hide them? See attached image...I want to hide what is in the red square.
10 years 10 months ago #219027
.naughty-red-square{
display:none;
10 years 10 months ago #219028
The red square was mine for emphasis. I don't want the tags to show
10 years 10 months ago #219029
Best will be to perform a view override for the product page, and remove the display of "show_block_tags" view which display the Joomla tags.
Time to create page: 0.163 seconds
