How to translate "Compare products" ?
12 years 1 month ago #173880 by wexword
-- Joomla version -- : 3.3.4
How to translate fraze "Compare products" ?
I try translate the fraze in all language files but no effect
Where is the fraze ??
12 years 1 month ago #173906 by Xavier
Via Configuration > Languages edit the desired language file and add the following string in the override part
COMPARE_PRODUCTS="Your text"
12 years 1 month ago - 12 years 1 month ago #174043 by wexword
I did via Configuration and via FTP, but stil no results
I was add fraze:
COMPARE_PRODUCTS="Porównaj produkty"
at the end of this file
.../language/pl-PL/pl-PL.com_hikashop.ini
When I select product on site there is still 'Compare Products' :S
www.cctv-serwis.pl
Problem solved
Compare Desk extension put its own text
Last edit: 12 years 1 month ago by wexword.
12 years 1 month ago #174076 by Xavier
Do you have done like this:
take.ms/dmYUb
If yes, thanks to enable the Language debug in the Joomla settings in order to see if there is an error in the used language file.
