translate "Related products"
11 years 11 months ago #182807 by Gyatso
-- url of the page with the problem -- : centerofrock.com
Good afternoon, I get not translate "Related products", how I can fix it? is not in the language file.
11 years 11 months ago #182820 by korzo
Replied by korzo on topic translate "Related products"
It's module title.
In the administration go to Extensions->Module manager, search for "Related products" and change module title.
The following user(s) said Thank You: AlainR
11 years 11 months ago #182814 by nicolas
That's the name of a module. Go in the Joomla modules manager and edit that "Related products" module and change the name to what you want.
The following user(s) said Thank You: Gyatso
8 years 9 months ago #287071 by fils
Replied by fils on topic translate "Related products"
Thank you, it was the same issue in our case.
It is really strange since the module was not published att all, however related product option was set below some pages.
What is I activate and publish a copy of the "related products" module on the right side with title "Recommended"? Always the first module name will be presented?
Introducing a sacend language will give us a headache, it is sure.
Anyway Hikashop is an excellent product, but this parameter should be put in the language file, That is my 2 cents.
8 years 9 months ago #287074 by nicolas
It is a module title and thus it is data, not interface. The language file is only for interface translation.
The module displays below the product page because you have it enabled in the "modules under the product page" setting of the HikaShop configuration.
7 years 9 months ago #303489 by AlainR
Replied by AlainR on topic translate "Related products"
Hello!
fils wrote: Introducing a sacend language will give us a headache, it is sure.
It's a real question : how to do to display a different title module when language switch ?
I create 3 modules with 3 differents titles (french, english, german) and with language association. I enabled the 3 modules in the "modules under the product page" setting of the HikaShop configuration. And now I have the 3 titles in 3 languages under my product ?!?
7 years 9 months ago #303490 by nicolas
You can have only one module for all the languages and translate the title of the module via Falang's interface like products text, etc.
That's what we usually recommend to translate module titles.
Now being able to take into account the language restriction of the modules in the "modules under the product page" setting is a good idea. We'll see what we can do regarding that.
3 years 5 months ago #352363 by Complicités Minérales
hi, bonjour
in the language files :
RELATED_PRODUCTS="Produits associés"
too bad it's not in the code for the product pages on version 4.7.3
chouette l'ancienne technique fonctionne quand même :-)
3 years 5 months ago #352365 by nicolas
It's actually not a matter of "not in the code".
The "Related products" text you see on the product page is the title of the module. The translation text is actually used when the module is being created during the installation of HikaShop. However, for the French translation to be used at that point, it requires you to be logged in in your backend in French, AND that the French language file of HikaShop is already in place on the website. If either is not true, you'll get the English name there.
