Hika on ice
12 years 11 months ago #133779
by RonyG
Hika on ice was created by RonyG
-- HikaShop version -- :Business + Serial - latest
-- Joomla version -- : 2.5
I installed the ICE Theme with full components and design on my Joomla.
I installed Hika Business and Serial
How exactly I make them to work together, is the Serial works with the JoomShopping?
12 years 11 months ago #133786
by Jerome
Replied by Jerome on topic Hika on ice
HikaSerial works with HikaShop.
There is no plugin for integration with JoomShopping.
You can generate (or import) serials in the backend, you can use the serial with some consumption plugins but you can't create dynamically a serial with a JoomShopping order and you can link a HikaSerial pack with a JoomShopping product.
12 years 11 months ago #133790
by RonyG
Replied by RonyG on topic Hika on ice
1 . thanks for your reply
2. i suggest you remove your recommendation of using ice theme if its just causing your clients to spend time and money on something that just do not work together.
3. I am asking for a solution on what to do next. I have a paid hika business, paid hika serial and paid ice theme.
I like the ICE theme very much and want to use their current design (IT_Shop2)
I prefer using Hika and Hika serial as our cart solution
I browsed some of the tickets and saw that you recommended removing JoomShopping but i am afraid to mess up everything. can someone just help me here?
12 years 11 months ago #133791
by Jerome
We do not recommend ice theme, where did you see that ?!
12 years 11 months ago #133792
by RonyG
Well, i didn't know ICE before reading all your documents...
I will locate it and send it over to you.
to the point - what do I do?
12 years 11 months ago - 12 years 11 months ago #133793
by Jerome
I still don't know anything about ICE, so I can't talk anything about it and I won't make any recommendation for it.
JoomShopping is an e-commerce system, HikaShop is another.
It's not that I don't want to make an integration with a "competitor" but, I don't see the interest.
You can ask for a refund, their is no problem.
Last edit: 12 years 11 months ago by Jerome.
12 years 11 months ago #133796
by RonyG
On your Help documents:
Other resources
Joomla templates optimized for HikaShop
Joomla Ecommerce template optimized for HikaShop by IceTheme
I just picked one of their themes that I liked and installed it.
I will asked them for refund as we prefer to continue with Hika.
can you recommend a good nice template that will easily integrated with Hika?
Other resources
12 years 11 months ago #133799
by Jerome
"ICE" made templatse for Joomla. They created one template compatible with HikaShop so we listed them in our documentation because they have one template compatible (and optimized) with HikaShop.
All of their templates are not optimized with HikaShop, I checked and they have only one (the template that we linked).
HikaSerial is an add-on for HikaShop, it means that it requires and it works with HikaShop.
There are very few elements in the front-end for HikaSerial (only one module, if you want to use it) so it will work with most of joomla template without any problem.
So I think that your question is more for HikaShop that for HikaSerial.
At this moment I will suggest you to ask in the HikaShop sections. I am not sure that they will have a lot more to say about templates.
HikaShop works with all template but some are "optimized" so they have a better look and integration for the e-commerce part.
I know that, recently Joomlabamboo made some cool templates optimized with HikaShop. I didn't see it yet but I eared very good feedback.
Because I am mainly working on HikaSerial and HikaMarket, I do not know a lot of things about templates around HikaShop. I am sorry but I won't be a really good support for this part.
About JoomShopping, I suppose that you have installed an ICE template for JoomShopping so you have installed JoomlShopping after that.
But, like I said in a previous post, JoomShopping is another e-commerce solution for Joomla so HikaShop and JoomShopping does not have real interest to be installed and used in the same time.
