- Thank you received: 26
Issue with Order Status Not Confirming When Using HikaSubscription
1 year 5 months ago - 1 year 5 months ago #367481
by Lumiga
Kind regards,
Lumiga
-- HikaShop version -- : 5.1.6
-- HikaSerial version -- : 5.1
-- Joomla version -- : 5.3.1
-- PHP version -- : 8
Hello HikaShop Support,
We’re experiencing an issue when using HikaSubscription in combination with HikaSerial.
When a customer places an order that includes a product linked to a subscription, the order status does not change to "confirmed" after payment. However, when we use a product without HikaSubscription, the order is correctly confirmed after purchase.
We followed this tutorial "Selling e-tickets with HikaSerial" to set up the club license:
Everything else works as expected:
If we manually change the order status to "confirmed", the serials are generated, the PDF is created, and the confirmation email is sent to the customer.
We would like to understand how to debug this issue and identify what’s preventing the order from being confirmed automatically.
Please find all relevant screenshots attached.
Thank you in advance for your help!
Best regards,
Lumiga
Best regards,
Lumiga
Kind regards,
Lumiga
Last edit: 1 year 5 months ago by Lumiga.
1 year 5 months ago #367487
by Jerome
Replied by Jerome on topic Issue with Order Status Not Confirming When Using HikaSubscription
What payment plugin are you using?
Depending "how" the order is confirmed (the kind of plugin), it can be launch in a context where a lot of RAM is already used.
And adding the generation of some PDF (and more) can be the source of your issue.
If the manual validation of the order is working, I do think that the confirmation of the order by the payment plugin is "too short" (in time, ressources, etc).
To debug that, we will need more details about the context ; maybe some elements could be found in the HikaShop logs, or the server logs.. It will depends.
1 year 5 months ago - 1 year 5 months ago #367500
by Lumiga
Kind regards,
Lumiga
Replied by Lumiga on topic Issue with Order Status Not Confirming When Using HikaSubscription
Hi Jerome,
We use RO Payments.
rolandd.com/products/ro-payments with the Hikashop plugin.
The only text in the Hikashop Payment log is:
In the serverlogs there where no issues.
Here you can find the log from RO Payments with a succesfull confirmation and the last one without.
This payment did not set the order to confirmed:
As you expected, there is indeed a difference in the log.
If you want I can sent you logincredetials.
Kind regards.
We use RO Payments.
<h3>03.28.25 13:33:58</h3>
The following From address failed: v..hidden..@..hidden...nl : MAIL FROM command failed,Error: nested MAIL command
,503,5.5.1SMTP server error: MAIL FROM command failed Detail: Error: nested MAIL command
SMTP code: 503 Additional SMTP info: 5.5.1
[2025-06-04 09:52:15] Gekozen kaart(en):
[2025-06-04 09:52:15] Set transaction details
[2025-06-04 09:52:15] Currency: EUR
[2025-06-04 09:52:16] Send customer to URL: https://www.mollie.com/checkout/select-method/DpnkHJzygq
[2025-06-04 09:52:23] Process directly
[2025-06-04 09:52:23] User agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/137.0.0.0 Safari/537.36
[2025-06-04 09:52:23] Query string: transaction_id=mollie_683ffb2fc8d72&output=customer
[2025-06-04 09:52:23] User Beheerder is calling.
[2025-06-04 09:52:23] Going to sleep
[2025-06-04 09:52:24] Waking up
[2025-06-04 09:52:24] Going to sleep
[2025-06-04 09:52:25] Waking up
[2025-06-04 09:52:25] Going to sleep
[2025-06-04 09:52:25] Process directly
[2025-06-04 09:52:25] User agent: Mollie HTTP client/1.0
[2025-06-04 09:52:25] Query string: transaction_id=mollie_683ffb2fc8d72
[2025-06-04 09:52:25] Payment provider calling
[2025-06-04 09:52:25] Get transaction ID
[2025-06-04 09:52:25] Received transaction ID mollie_683ffb2fc8d72
[2025-06-04 09:52:25] Get transaction status
[2025-06-04 09:52:25] id:tr_DpnkHJzygq
[2025-06-04 09:52:25] transaction_id:mollie_683ffb2fc8d72
[2025-06-04 09:52:26] Received payment status: paid
[2025-06-04 09:52:26] Has chargebacks: No
[2025-06-04 09:52:26] Received card: ideal
[2025-06-04 09:52:26] Set transaction details
[2025-06-04 09:52:26] Payment sequence: oneoff
[2025-06-04 09:52:26] Payment has SUCCESS status
[2025-06-04 09:52:26] Current order status P
[2025-06-04 09:52:26] Send customer change status email
[2025-06-04 09:52:26] {"order_number":"B-00017","order_id":17,"order_total":"25.00000","order_status":"C","user_email":"info@lucians.eu","order_comment":"Transaction number: mollie_683ffb2fc8d72"}
[2025-06-04 09:52:26] Send admin order payment email
[2025-06-04 09:52:26] Notifying extension on URL: https://hidden-url.nl/index.php?option=com_hikashop&ctrl=checkout&task=notify¬if_payment=jdideal&tmpl=component&lang=nl&Itemid=3008&transactionId=mollie_683ffb2fc8d72&pid=f0XDUEYPRkXIfdN9UnMUtIpD99OJfDCssUDkECyaXFO7QZY33a
[2025-06-04 09:52:26] Notify method: get
[2025-06-04 09:52:26] Coming in on https://hidden-url.nl/cli/notify.php?transaction_id=mollie_683ffb2fc8d72
[2025-06-04 09:52:26] Calling RO Payments on https://hidden-url.nl/index.php?option=com_jdidealgateway&task=checkideal.request&format=raw&redirect=aHR0cHM6Ly92ZXJndW5uaW5nZW4uc3ZiZGVsZmxhbmQubmwvaW5kZXgucGhwP29wdGlvbj1jb21faGlrYXNob3AmY3RybD1jaGVja291dCZ0YXNrPW5vdGlmeSZub3RpZl9wYXltZW50PWpkaWRlYWwmdG1wbD1jb21wb25lbnQmbGFuZz1ubCZJdGVtaWQ9MzAwOCZ0cmFuc2FjdGlvbklkPW1vbGxpZV82ODNmZmIyZmM4ZDcyJnBpZD1mMFhEVUVZUFJrWElmZE45VW5NVXRJcEQ5OU9KZkRDc3NVRGtFQ3lhWEZPN1FaWTMzYQ==
[2025-06-04 09:52:26] Starting payment notification
[2025-06-04 09:52:26] Order status is created
[2025-06-04 09:52:26] Modifying order 17 to status confirmed
[2025-06-04 09:52:26] Waking up
[2025-06-04 09:52:26] Going to sleep
[2025-06-04 09:52:27] Received HTTP status 200
[2025-06-04 09:52:27] Trigger callback on extension addon: HikaShop
[2025-06-04 09:52:27] Setting payment as processed
[2025-06-04 09:52:27] Waking up
[2025-06-04 09:52:27] Result: SUCCESS
[2025-06-04 09:52:27] Is transaction processed: Yes
[2025-06-04 09:52:27] Redirecting customer to: https://hidden-url.nl/index.php?option=com_hikashop&ctrl=checkout&task=after_end&order_id=17&order_token=mWJylxkx&Itemid=3008&transactionId=mollie_683ffb2fc8d72&pid=f0XDUEYPRkXIfdN9UnMUtIpD99OJfDCssUDkECyaXFO7QZY33a
[2025-06-06 09:47:51] Gekozen kaart(en):
[2025-06-06 09:47:51] Set transaction details
[2025-06-06 09:47:51] Currency: EUR
[2025-06-06 09:47:52] Send customer to URL: https://www.mollie.com/checkout/select-method/vN9XTPdP4WPjV63KrFe9J
[2025-06-06 09:48:00] Process directly
[2025-06-06 09:48:00] User agent: Mollie HTTP client/1.0
[2025-06-06 09:48:00] Query string: transaction_id=mollie_68429d2791f4e
[2025-06-06 09:48:00] Payment provider calling
[2025-06-06 09:48:00] Get transaction ID
[2025-06-06 09:48:00] Received transaction ID mollie_68429d2791f4e
[2025-06-06 09:48:00] Get transaction status
[2025-06-06 09:48:00] id:tr_vN9XTPdP4WPjV63KrFe9J
[2025-06-06 09:48:00] transaction_id:mollie_68429d2791f4e
[2025-06-06 09:48:00] User agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/137.0.0.0 Safari/537.36
[2025-06-06 09:48:00] Query string: transaction_id=mollie_68429d2791f4e&output=customer
[2025-06-06 09:48:00] User Lucians-Administrator is calling.
[2025-06-06 09:48:00] Going to sleep
[2025-06-06 09:48:00] Received payment status: paid
[2025-06-06 09:48:00] Has chargebacks: No
[2025-06-06 09:48:00] Received card: ideal
[2025-06-06 09:48:00] Set transaction details
[2025-06-06 09:48:00] Payment sequence: oneoff
[2025-06-06 09:48:00] Payment has SUCCESS status
[2025-06-06 09:48:00] Current order status P
[2025-06-06 09:48:00] Send customer change status email
[2025-06-06 09:48:00] {"order_number":"B-00018","order_id":18,"order_total":"0.25000","order_status":"C","user_email":"info@lucians.nl","order_comment":"Transaction number: mollie_68429d2791f4e"}
[2025-06-06 09:48:00] Send admin order payment email
[2025-06-06 09:48:00] Notifying extension on URL: https://hidden-url.nl/index.php?option=com_hikashop&ctrl=checkout&task=notify¬if_payment=jdideal&tmpl=component&lang=nl&Itemid=3008&transactionId=mollie_68429d2791f4e&pid=BstzrpuJtGHEhOzY6Kp0iAG4H1ndp7adIypfOmAOM9yrzdMW58
[2025-06-06 09:48:00] Notify method: get
[2025-06-06 09:48:00] Coming in on https://hidden-url.nl/cli/notify.php?transaction_id=mollie_68429d2791f4e
[2025-06-06 09:48:00] Calling RO Payments on https://hidden-url.nl/index.php?option=com_jdidealgateway&task=checkideal.request&format=raw&redirect=aHR0cHM6Ly92ZXJndW5uaW5nZW4uc3ZiZGVsZmxhbmQubmwvaW5kZXgucGhwP29wdGlvbj1jb21faGlrYXNob3AmY3RybD1jaGVja291dCZ0YXNrPW5vdGlmeSZub3RpZl9wYXltZW50PWpkaWRlYWwmdG1wbD1jb21wb25lbnQmbGFuZz1ubCZJdGVtaWQ9MzAwOCZ0cmFuc2FjdGlvbklkPW1vbGxpZV82ODQyOWQyNzkxZjRlJnBpZD1Cc3R6cnB1SnRHSEVoT3pZNktwMGlBRzRIMW5kcDdhZEl5cGZPbUFPTTl5cnpkTVc1OA==
[2025-06-06 09:48:00] Received HTTP status 200
[2025-06-06 09:48:00] Trigger callback on extension addon: HikaShop
[2025-06-06 09:48:00] Setting payment as processed
[2025-06-06 09:48:01] Waking up
[2025-06-06 09:48:01] Result: SUCCESS
[2025-06-06 09:48:01] Is transaction processed: Yes
[2025-06-06 09:48:01] Redirecting customer to: https://hidden-url.nl/index.php?option=com_hikashop&ctrl=checkout&task=after_end&order_id=18&order_token=w4eqy4bu&Itemid=3008&transactionId=mollie_68429d2791f4e&pid=BstzrpuJtGHEhOzY6Kp0iAG4H1ndp7adIypfOmAOM9yrzdMW58
Kind regards.
Kind regards,
Lumiga
1 year 5 months ago #367520
by Jerome
If the payment plugin is not confirming the order, there is nothing I can do in HikaSerial.
