- Thank you received: 1
what does it do? HikaShop serial product-add check
13 years 6 months ago - 13 years 6 months ago #103045
by dado023
what does it do? HikaShop serial product-add check was created by dado023
Last edit: 13 years 6 months ago by dado023.
13 years 6 months ago #103051
by Jerome
Replied by Jerome on topic what does it do? HikaShop serial product-add check
To access to the configuration of HikaSerial plugins, you have to use the HikaSerial interface.
In the backend: HikaSerial > Plugins.
At this moment you will see the consumer plugin "Product Add".
This consuming plugin allow you to link a serial to a product.
When a user will try to consume a serial, the plugin will add the specific product in his cart.
There is an option in order to block the product so, users who does not have "used" the serial can't buy the product. They have to fill the serial in the HikaSerial consume page (or module) to add the product in the cart and have the right to buy it.
This plugin can be useful if you want to have some free products thanks to codes.
13 years 6 months ago #103058
by dado023
Replied by dado023 on topic what does it do? HikaShop serial product-add check
aha, so if i get this right, this would be ideal for unlocking a product with a secret key code?, right?
13 years 6 months ago #103064
by Jerome
Exactly, yes.
Unlocking a special product which could have a price or could be free.
Exactly, yes.
13 years 4 months ago - 13 years 4 months ago #112576
by lionel75
Replied by lionel75 on topic what does it do? HikaShop serial product-add check
Does Hikaserial support
1 create a group of fixed number of key , where key are not predefine, hikaserial do it for us
2 use a group of predefine keys
does Hikaserial implement the way the serial key ll be shown ?
1 shape => bar code , raw text
2 format support => html with css/image, raster,doc, pdf,svg
does Hikaserial implement the way the serial key ll be send ?
1 protocol smtp / sms / http after login
thank's
thank's
Last edit: 13 years 4 months ago by lionel75.
13 years 4 months ago #112632
by Jerome
I really don't understand what you mean.
HikaSerial is a sort of big toolbox which uses plugins for the generation of the serial, for the consumption, for the display, etc.
www.hikashop.com/en/hikashop/124-hikaserial-plugins.html
The generation plugin allow you to create dynamically serials or populate a group with serials (so you can create the number of serials you want).
The plugin "attach serial" just generate images, but it can display bar code, QR codes, raw text, etc.
It is a very cool plugin, I recommend you to read a little more his documentation because you can do great things with it.
There is no such plugin in HikaSerial but it is possible to implement such things.
HikaSerial is enough flexible to permit these features (thanks to plugins).
13 years 4 months ago #112648
by lionel75
Yes i ll take time for read the forum and test all options
Thank's
Thank's
