- Thank you received: 1
I can not add serials to products in front end?
12 years 3 months ago #166477
by 888
I can not add serials to products in front end? was created by 888
-- HikaSerial version -- : 1.8.3
-- Joomla version -- : 3.3.3
-- PHP version -- : 5.5.14-1
I can not add serials to products in front end? no matter what I do in ACL
I see it, When I click on the cross(add) nothing happens the link is #
12 years 3 months ago #166479
by Jerome
Replied by Jerome on topic I can not add serials to products in front end?
The integration between HikaMarket and HikaSerial is for the moment still "simple".
You can create HikaSerial packs in the front-end but you can associate an existing HikaSerial pack (so, created in the backend) to a product in the front-end.
By activating the ACL (product / edit / plugins / hikaserial) you allow HIkaSerial to display his content like it display his content in the backend product edition.
The cross button should open a popup to select an HikaSerial pack but it looks like there is a javascript problem with Joomla 3.3
The best is to edit the view "front-end | your front-end template | productserial | market_block" (or directly the file "components/com_hikaserial/views/productserial/tmpl/market_block.php") and replace
By
in the beginning of the view.
It will force the inclusion of the HikaSerial javascript and will open correctly the modal box in the product page.
We will update the HikaSerial package as soon as possible.
if(!defined('HIKAMARKET_COMPONENT'))
return;
return;
$doc = JFactory::getDocument();
$doc->addScript(HIKASERIAL_JS.'hikaserial.js');
12 years 3 months ago #166488
by 888
Replied by 888 on topic I can not add serials to products in front end?
I did edit "components/com_hikaserial/views/productserial/tmpl/market_block.php") and replace code
but When I click on the cross(add) nothing happens the link is #
12 years 3 months ago #166491
by Jerome
So I think the modal is right open but your template is not compatible with the bootstrap modals (so the modal is not visible in the page, due to some bootstrap missing CSS)
Please change the option "popup mode" to "mootools" in your HikaShop configuration (System > Configuration > Display > General display options).
www.hikashop.com/support/support/documen...html#display_general
12 years 3 months ago #166503
by 888
it works now
and i did edit market_block.php to orginal and it work to
thanks
thanks
12 years 3 months ago #166505
by 888
I can add but not save or apply it will not stick to the product
12 years 3 months ago #166507
by Jerome
I've update your HikaSerial with the latest build.
The saving problem is now fixed.
Sorry for the inconvenient.
12 years 3 months ago #166508
by 888
awesome
thanks for quick reply
