Problem with plugin: Group filter consumer
11 years 10 months ago #187825
by kaimor
Problem with plugin: Group filter consumer was created by kaimor
-- HikaSerial version -- : 1.9.0
-- Joomla version -- : 3.3.6
Hi!
The choices under GROUPS are grey, and cannot be selected.
I have selected "Pack", named the new plugin and saved the new plugin.
What am I doing wrong?
Hi!
11 years 10 months ago #187840
by Jerome
Replied by Jerome on topic Problem with plugin: Group filter consumer
The checkboxes can be checked ; I just try in our demo website and there is no problem.
11 years 10 months ago #187846
by kaimor
Replied by kaimor on topic Problem with plugin: Group filter consumer
I can make selections. But when I press save, the selections dissapear.
11 years 10 months ago #187847
by kaimor
I tried it on your testpage, and the same happened there.
demo.hikashop.com/administrator/index.ph...aserial&ctrl=plugins
11 years 10 months ago #187848
by Jerome
Thanks, I see now !
Please edit the file "administrator/components/com_hikaserial/views/plugin/view.html.php" and replace
By
It will fix the issue and this patch will be include in the next HikaSerial release.
Thanks for the report.
Thanks, I see now !
$aclType = hikaserial::get('type.acl');
$html .= $aclType->display($key, @$this->element->$paramsType->$key, $type.']['.$paramsType);
$html .= $aclType->display('data['.$type.']['.$paramsType.']['.$key.']', @$this->element->$paramsType->$key);
The following user(s) said Thank You: kaimor
11 years 10 months ago #187859
by kaimor
