attachserial input field for ean
11 years 7 months ago - 11 years 7 months ago #199251 by lionel75
-- HikaSerial version -- : 1.9.1
-- Joomla version -- : 2.5.28
-- PHP version -- : 5.5.17
1) I test attachserial and when create ticket ; there is 2 input form when create ean area in the image raster ticket . Can i know howto to use them ?
Attachment not found
2) i enable 2 plugin attachserial ean and HikaSerial . Do i need to enable another one explicitly for consume serial like "Product-add consumer" ?
when i edit this last plug in i have
Fatal error: Call to undefined method hikashopProductClass::getTreeList() in administrator/components/com_hikashop/types/productdisplay.php on line 130
Is it logic ?
3) move bug to bug chapter
Regard's
Last edit: 11 years 7 months ago by lionel75.
11 years 7 months ago #199281 by Jerome
1) You can't, unless you have read the documentation corresponding to that plugin.
2) In a way, this bug is logical yes.
But the good news is that the issue is already fixed in HikaShop since middle March and will be available in the next HikaShop release.
3) What's the link with HikaSerial ?
11 years 7 months ago #199347 by lionel75
1)
i search in the hikaserial documentation and i find
1a "Format - The output format (raw text, a formatted date, a qrcode or a barcode). Some format can have extra parameters. " but no information about parameters ( empty input field 1 and 2 higlight in green in my capture screenn)
1b "Barcode - Display the content as a Barcode (format EAN13), the content as to be compatible with this format.. " But nothing about the 2 empty fields
2)
3) discover this when use hikaserial to see after buy a product and see if change in order BE. I put it to bug section
11 years 7 months ago #199349 by Jerome
1) The two inputs are the for parameters.
So the first input is for the parameters for the type and the second input for the format.
www.hikashop.com/support/documentation/1...ns-attachserial.html
In the documentation, when it is written that you have to specify something, it means that you have to enter it in the input box below the dropdown.
Like:
Raw Text... - Display a raw text, the exact same text you will specify.
or
Date - Display the content as a date. You have to specify a date format (using %Y, %m, %d...).
3) okay
11 years 7 months ago - 11 years 7 months ago #199452 by lionel75
In most of the case like programming implicit can be understand if you have the knowledge/skill on the subject i don't have ....
It is like the word "namekey" i can read many occurrence in the documentation that i don't understand ....
thank's a lot
11 years 7 months ago #199454 by Jerome
When you create a custom field, you have to specify a "namekey" ; this "namekey" will be use for the column name in the database.
So to generalize, the namekey refer to the name of the column in the database.
The following user(s) said Thank You: lionel75
