Serial Block missing in product interface
14 years 3 weeks ago - 14 years 2 weeks ago #70111 by Informatics
i missing the "Serial" block in the product interface.
I have created a pack of random serial, but i can't add this pack to a product.
I tested this on a blank joomla instance, but there is the same issue.
anyone the same issue?
regards
edit1:
Now i have installed joomla on my web server. There is no problem.
I think the problem is in xampp.
edit2:
the newest xampp 1.8.1 run with PHP 5.4.7
i use now xampp 1.7.4 with PHP 5.3.5 and now it's ok...
hope this help
Last edit: 14 years 2 weeks ago by Informatics. Reason: Add Solution
14 years 2 weeks ago #70320 by Jerome
It might be a problem with PHP 5.4
With HikaShop 2.0 and HikaSerial 1.5 we would add the support of PHP 5.4, I would make more tests on this specific part and found the problem.
Thanks for the report.
