GC Serial Problems
When I go through a sale on a gift certificate, I do not get the serial number assigning nor do I receive the download address for the file pdf in the email.
What am I doing wrong?
Serials are generated when the order is confirmed.
Download files are accessible when the order is confirmed.
If you want you can configure and change the "valid" order statuses for serials and download access.
Now I did get the confirmation email link and when I click it, it says "INVALID_FILE_NUMBER" .
There is no indication of a serial number in the email. When I view the order in my browser I can only see underneath in text the word "serials"
There was a bug in HikaShop 2.0 with file download.
Please re-download HikaShop 2.0 to fix this problem.
In order to change the configuration of "serial assignation"
www.hikashop.com/en/hikashop/111-hikaser...nable_order_statuses
In the HikaShop back-end, open your order.
You should see a "Serials" zone with a "Refresh associations" button at the right.
If the serial table is empty, click on the "refresh" button to reprocess serial associations (it could happen if the hikaserial configuration changed after the order last modification).
I have modified the default view for "show_order_front_show" in order to do not display the title "Serials" when there is no serial attached to the order.
This modification would be include in the next package (1.5.1)
I made the gift certificate pdf download say "... fill in the "To:___, From:___, Serial#:____" and then - if the recipient enters the serial number into the online cart they can use this amount of the gift certificate for shopping.
So where do I assign the dollar value to the serial? And where will they type the serial number in on Hikashop checkout?
The coupon generator plugin documentation could help you for this point :
www.hikashop.com/en/hikashop/139-hikaser...-coupongen-form.html
When you create a configuration for the coupon generator, you attach the configuration to a specific coupon, so to a specific value.
You have to create 3 coupon templates for 3 configurations for your 3 different coupon values.
Each time a serial would be generated, a HikaShop coupon would be generated by HikaSerial.
Coupon could be use during the checkout, in the task "coupon".
If the task is not in your checkout workflow, you should add it.
Jerome wrote: Hi,
You can send me a private message with some backend access and I will check your configuration.
The HikaSerial option "Assignable order statuses" was empty.
I set the default values "confirmed,shipped" and the serials are now assigned correctly.
Jerome wrote: Hi,
