- Thank you received: 2
HikaSerial/HikaShop product quantity not working
13 years 11 months ago - 13 years 11 months ago #80303
by d2dpcs
HikaSerial/HikaShop product quantity not working was created by d2dpcs
I linked the product quantity between HikaShop and HikaSerial successfully. While testing the import of serials, the product quantity updated properly. When I deleted the serials I used while testing the imports, the product quantity DID NOT update properly. They are removed from the Serials list, but the number of products is not lowered in the backend or frontend.
Edit: Removing quantity, and saving, when viewing product in HikaShop fixed the issue. I would rather not have to do this, though.
Thanks,
Eric
Thanks,
Eric
Last edit: 13 years 11 months ago by d2dpcs. Reason: marked solved
13 years 11 months ago - 13 years 11 months ago #80326
by Jerome
Replied by Jerome on topic HikaSerial/HikaShop product quantity not working
Thansk for the report.
I have made a patch which would be in the next release (1.5.1)
You can edit the file "administrator/com_hikaserial/classes/serial.php" and update the delete function.
You just have to add two line just before the end of the function
With it, the product quantity link would be reprocess (synchronize) each time a serial is deleted.
public function delete($elements) {
// Content of the "delete" function.
// Update product quantity - Just add these two lines at the end of the function, before the last "return".
$productClass = hikaserial::get('class.product');
$productClass->refreshQuantities();
return $result;
Last edit: 13 years 11 months ago by Jerome.
13 years 11 months ago - 13 years 11 months ago #80437
by d2dpcs
Replied by d2dpcs on topic HikaSerial/HikaShop product quantity not working
Thanks for the immediate response as always. I edited the file with your two lines before, and outside, the return false bracket (received error upon deleting serial) and within the bracket like below (serial deleted, but did not update product quantity). Thanks, Eric.
if(!is_array($elements)) {
$elements = array($elements);
$config = hikaserial::config();
JPluginHelper::importPlugin('hikaserial');
$dispatcher = JDispatcher::getInstance();
$do = true;
$dispatcher->trigger('onBeforeSerialDelete', array(&$elements, &$do));
if(!$do) {
return false;
13 years 11 months ago #80703
by d2dpcs
Jerome, I see that you thanked me, but didn't address the fact that it didn't work for me. I'm just writing this to let you know that a little bit of clarification is needed. Thanks, Eric.
13 years 11 months ago #80710
by Jerome
Sorry, I misunderstood your previous message.
After using the code tag on your tag, I see that your modification is not the right one.
The code should be at the end of the function, at the "real" end.
$dispatcher->trigger('onAfterSerialDelete', array(&$elements));
return $result;
public function consume($serial_id, $extra_data = null, $checkUser = true) {
The following user(s) said Thank You: d2dpcs
13 years 11 months ago #80713
by d2dpcs
Yes, that worked for me. Thanks for the clarification.
Time to create page: 0.087 seconds
