Associate HS product with Pack Serial at importing
- adesjohnson
13 years 10 months ago #84124
by adesjohnson
Associate HS product with Pack Serial at importing was created by adesjohnson
Hello:
I need to associate some 600 HS products with packs of serials. It would be very tiring to do this manually, is there a way to do this using the Import Products option (Products - Import)?
Thank you,
John.
Thank you,
John.
13 years 10 months ago #84163
by Jerome
Replied by Jerome on topic Associate HS product with Pack Serial at importing
The best solution is to implement the feature directly in HikaSerial, in his import system.
Which information would be use for products and packs ?
Do you want to use the product_id or the product_code ?
Do you want to use the pack_id or the pack_name ?
- adesjohnson
13 years 10 months ago #84167
by adesjohnson
Replied by adesjohnson on topic Associate HS product with Pack Serial at importing
Jerome:
"The best solution is to implement the feature directly in HikaSerial, in his import system."
O.K. Good.
"Which information would be use for products and packs ?"
Around 600 HS products associated to some packs (containing unique numbers NOT generated but imported).
"Do you want to use the product_id or the product_code?"
I would prefer product_code.
"Do you want to use the pack_id or the pack_name ?"
I would prefer pack_name.
Thank you.
Jerome:
O.K. Good.
Thank you.
13 years 10 months ago #84298
by Jerome
I am working on it, it would be add in the next release of HikaSerial.
So it would be possible to import "product pack" associations and set the quantity.
A quantity of "0" would remove the association from the database.
- adesjohnson
13 years 10 months ago #84299
by adesjohnson
O.K. Thank you. And when would the next release be?
13 years 10 months ago #84470
by Jerome
I don't have other feature request for the moment so, after the development of the new import system, I think I would release the new version.
13 years 10 months ago #84728
by Jerome
The import system is now finished and tested.
You can import a CSV with this format:
pack_name and pack_id are supported.
product_code and product_id are supported.
pack_quantity is optional, if not set the value 1 would be used. You can use the value "0" to delete an association.
I am building the new release.
pack_name,product_code,pack_quantity
"License Pack 1","product_001",1
"License Pack 1","product_002",2
"License Pack 2","product_003",1
"License Pack 3","product_004",1
- adesjohnson
13 years 10 months ago #84741
by adesjohnson
Jerome:
Many, many thanks to you. I'm waiting for the new release.
Thank you,
John.
Jerome:
Thank you,
John.
13 years 9 months ago #84897
by Jerome
HikaSerial 1.6.0 is now accessible for download.
The following user(s) said Thank You: maxwel
13 years 9 months ago #84924
by maxwel
Replied by maxwel on topic Associate HS product with Pack Serial at importing
I installed the new version 1.6.0, tried the new feature and worked well for my purposes.
Thank you Jerome very much!!!
13 years 9 months ago #84926
by Jerome
Thanks !
I have just made a little update for the plugin "coupon generator". The "dynamic value" works better now.
You can specify a percentage and the coupon value would be the percentage of the associated product. So it would be easier to create coupons without creating a lot of coupon templates.
Thanks !
