- Thank you received: 4
How does serial pack generation work
13 years 2 months ago #121090
by intown
How does serial pack generation work was created by intown
mywebsite.com/mypage
-- HikaShop version -- : 2.2.1
-- Joomla version -- : 3.1.5
I am a little confused about how HikaSerial should work.
I have created my pack of series generator plugin, which starts at 2001 and ends at 3000
I then created my pack using the 'Pack SQL Data' and the pack generator I created.
This pack is attached to a product.
I the stats show 0 serials available and 1 used (I went through the checkout process once)
Should I do something to actually generate all of my serial numbers?
I feel like I am missing a step here.
Thanks! -- Steven
Thanks! -- Steven
13 years 2 months ago #121096
by Jerome
Replied by Jerome on topic How does serial pack generation work
You are using a serial generator so the serials will be created when it will be necessary.
If you want, you can use the "generate" button in the "pack edition" screen. But in your case, the serials will be generated automatically.
www.hikashop.com/support/documentation/117-pack-edition.html
13 years 2 months ago #121128
by intown
Replied by intown on topic How does serial pack generation work
Thanks so much for the reply.
I was able to generate 1000 serial numbers. Which is all I need for now.
After Generating the 1000 serial numbers in my Pack can I set
Pack Data to 'No Pack data Provider'
Pack Generator to None
And then the system would proceed to use up the 1000 serial numbers that I created?
Later if I needed a few more serial number I could generate them and put the setting back to "off"
I think I am starting to get the hang of it.
Thanks! -- Steven
Thanks! -- Steven
13 years 2 months ago #121144
by Jerome
If your populate your pack with the 1000 serials you needs, you can remove the generator from the pack configuration.
But don't touch to the "Pack Data", if you remove it, HikaSerial won't be able to retrieve the serial data from the database. So the pre-generated serials won't have any impact.
First HikaSerial get available serial using the "pack data" option. Then it uses the generator to create new one.
If you remove both options, HikaSerial will do nothing.
If you have just the pack generator, HikaSerial won't use or reuse a serial in the database.
