Multivendor Add product code duplicate issue
13 years 3 months ago - 13 years 3 months ago #115332 by xsbucks
I am having an issue with the code value on product upload. We are just in the middle of bug testing our site and came across this.
Scenario.
Add Product Form.
I have excluded Code from the ACL , I don't want clients to get too overwhelmed and confused.
Entry of the title, example. Test
There is already a product named Test existing. If gives the following error
A product with the same code already exists
Any simple way to add a sequential number to code section only of the product being uploaded to avoid this?
Last edit: 13 years 3 months ago by xsbucks.
13 years 3 months ago #115339 by Jerome
What do you mean with the "product being uploaded" ?
13 years 3 months ago - 13 years 3 months ago #115342 by xsbucks
Under 'Add New Product' in the front end upload.
on save of product with the same title as existing product, Is there something i can do to have duplicate titles to have a different code?
ie..
Product 1
Title = Test Code = Test
Product 2
Title = Test Code = Test1
Product 3
Title = Test Code = Test2
Product 4
Title = Test Code = Test3
and so on ......
13 years 3 months ago #115363 by Jerome
For the same vendor or for different vendors ?
Do you think that an option to set automatically a prefix for the vendor product codes could be interesting ?
13 years 3 months ago #115372 by xsbucks
This was happening with different vendors with the same [Title]. I think that would be beneficial, however i think a sequential number after the code would be a bit less buggy, and allow one vendor to have multiple titles the same. In my instance anyway that would be.
Your guys support is absolutely amazing i am going to say. Top Shelf
13 years 3 months ago - 13 years 3 months ago #115375 by xsbucks
Tried SQL Manipulate , Already an AI in the the Table.
13 years 3 months ago #115481 by Jerome
I am working on a patch in the same time than the patch for the template data during saving.
I talked with Nicolas, we will see how to improve this product_code generation for HikaShop and HikaMarket.
13 years 3 months ago #115611 by xsbucks
Thanks Jerome.
13 years 3 months ago #115698 by Jerome
Still working on the algorithm.
Creating an incremental suffix could be complicated because we have to load every product codes which have the same "pattern" and make a loop to find an available number.
So I am trying to just loading the last product code with the same "pattern", the product code with the higher number but you can have false positives.
For example if your product code is "test" and you have "test_1", "test_2" in your database. The last element will be "test_2" so the algorithm will work.
But if you have a product code "test_test" in your database, it will be retrieve as the last element during the sort, so we won't be able to find the right prefix.
I don't want to use a SQL "regex" because it will be too much. So if I don't find a number suffix for the last element in my query, I use the "product id" as the number in the suffix.
I have to make more test but it should abort the error message (and save the product).
I wondering if showing a notice message telling that the product code was already used so a new one has been generated, could be interesting.
13 years 3 months ago #115952 by xsbucks
That actually would be perfect as there is a unique product id anyway. Use that as a prefix for the code. Brilliant. I am testing that out as well where its not too heavy on the sql. If i come up with it soon i will let you know.
13 years 3 months ago #115965 by Jerome
I have finish to test the patch for the HikaMarket Product class.
You can add into the class file "administrator/components/com_hikamarket/classes/product.php" this new function:
/** * */ protected function checkProductCode(&$product) { $config = hikamarket::config(); // // Vendor Prefix // $vendor_id = hikamarket::loadVendor(false, false); $vendor_prefix = $config->get('prefix_product_code', null); if(!empty($vendor_prefix) && $vendor_id > 1) { $prefix = 'v' . $vendor_id . '_'; if(is_string($vendor_prefix)) { $prefix = $vendor_prefix . $vendor_id . '_'; if(strpos($vendor_prefix, '%d') !== false) $prefix = sprintf($vendor_prefix, $vendor_id); } if(substr($product->product_code, 0, strlen($prefix)) != $prefix) $product->product_code = $prefix . $product->product_code; } // // Duplicate product code check // if(!$config->get('abort_duplicate_product_code', 0)) return; // Get the current product_id or determine which value it will be // if(!empty($product->product_id)) { $futur_product_id = $product->product_id; } else { $query = 'SELECT MAX(`product_id`) FROM '.hikamarket::table('shop.product'); $this->db->setQuery($query); $futur_product_id = (1 + (int)$this->db->loadResult()); // Generate a product code based on what we have // if(empty($product->product_code)) { $test = ''; if(!empty($product->product_name)) { $search = explode(',','ç,æ,œ,á,é,í,ó,ú,à,è,ì,ò,ù,ä,ë,ï,ö,ü,ÿ,â,ê,î,ô,û,å,e,i,ø,u'); $replace = explode(',','c,ae,oe,a,e,i,o,u,a,e,i,o,u,a,e,i,o,u,y,a,e,i,o,u,a,e,i,o,u'); $test = str_replace($search, $replace, $product->product_name); $test = preg_replace('#[^a-z0-9_-]#i', '', $test); } if(empty($test)) { $product->product_code = 'product_' . $futur_product_id; } else { $test = str_replace($search, $replace, $product->product_name); $product->product_code = preg_replace('#[^a-z0-9_-]#i', '_', $test); } } } if(!empty($product->product_code)) { if(empty($product->product_id)) { $query = 'SELECT COUNT(*) FROM '.hikamarket::table('shop.product').' WHERE product_code = '.$this->db->Quote($product->product_code); $this->db->setQuery($query); $isSame = ((int)$this->db->loadResult() > 0); } else { $query = 'SELECT COUNT(*) FROM '.hikamarket::table('shop.product').' WHERE product_code = '.$this->db->Quote($product->product_code).' AND product_id != '.(int)$product->product_id; $this->db->setQuery($query); $isSame = ((int)$this->db->loadResult() > 0); } if($isSame) { if(HIKASHOP_J30) $productCodeEscaped = "'" . $this->db->escaped($product->product_code . '_', true) . "%'"; else $productCodeEscaped = "'" . $this->db->getEscaped($product->product_code . '_', true) . "%'"; $query = 'SELECT product_code FROM '.hikamarket::table('shop.product').' WHERE product_code LIKE '.$productCodeEscaped; if(!empty($product->product_id)) { $query .= ' AND product_id != '.(int)$product->product_id; } $query .= ' ORDER BY product_code DESC'; $this->db->setQuery($query, 0, 1); $last_product_code = $this->db->loadResult(); $suffix = substr($last_product_code, 0, strlen($product->product_code) + 1); if(!empty($suffix) && (int)$suffix > 0) $product->product_code .= '_' . ((int)$suffix + 1); else $product->product_code .= '_' . $futur_product_id; $warning_message = JText::_('WARNING_DUPLICATE_PRODUCT_CODE_MODIFIED'); if(!empty($warning_message)) { $app = JFactory::getApplication(); $app->enqueueMessage($warning_message); } } } }
After that, you have to modify the "save" function. So replace:
public function save(&$product) { JPluginHelper::importPlugin('hikamarket'); $productClass = hikamarket::get('shop.class.product'); $status = $productClass->save($product); return $status; }
By this:
public function save(&$product) { $this->checkProductCode($product); JPluginHelper::importPlugin('hikamarket'); $productClass = hikamarket::get('shop.class.product'); $status = $productClass->save($product); return $status; }
In order to activate the feature, you have to create a new entry in the HikaMarket configuration.
You can use the new SQL query (replace "#_" by your database prefix. Like: "jos_hikamarket_config")
INSERT INTO `joom25`.`#__hikamarket_config` (`config_namekey`,`config_value`,`config_default`) VALUES ('abort_duplicate_product_code','1','0')
You can add a translation for the text "WARNING_DUPLICATE_PRODUCT_CODE_MODIFIED". If the translation is empty, no message will be displayed when a duplicate product code will be detect/modified.
13 years 3 months ago #116029 by xsbucks
Awesome! Thanks Jerome, One question, In which file is the "After that, you have to modify the "save" function. So replace:" code?
13 years 3 months ago #116047 by nicolas
in the same file, "administrator/components/com_hikamarket/classes/product.php"
13 years 3 months ago #116139 by xsbucks
ahh Thanks Nicolas, I was for some reason trying to find them in Hikashop.... not hikamarket.....
Parse error: syntax error, unexpected T_PROTECTED in /home/*******/public_html/******/administrator/components/com_hikamarket/classes/product.php on line 93
Is the error I am getting on the site now
13 years 3 months ago #116177 by Jerome
I think you paste the function in the wrong place in the file.
You have to paste it just after:
The following user(s) said Thank You: xsbucks
13 years 3 months ago #116313 by xsbucks
Brilliant!
13 years 3 months ago #116318 by xsbucks
That worked perfectly! You guys are unbelievable!
13 years 3 months ago #116320 by Jerome
Good to know.
The feature/function will be include in the next HikaMarket release, with the other new features.
Options will be introduce in the configuration part in order to activate it easily.
13 years 3 months ago #116327 by xsbucks
One thing I am not sure we can fix or not, When i refresh on the Successfully Saved page after creating a new product, It adds the same product again but with the next sequential number ( As a new product)
13 years 3 months ago #116387 by Jerome
The solution would be to redirect the user to the product edition page just after the product creation.
So when the user will try to refresh the page, it will just refresh the product edition page, not the previous creation form.
Time to create page: 0.127 seconds
