problem to show icons in vendor panel
- orchideelab
13 years 3 months ago - 13 years 3 months ago #117785
by orchideelab
problem to show icons in vendor panel was created by orchideelab
Last edit: 13 years 3 months ago by Jerome.
13 years 3 months ago #117827
by Jerome
Replied by Jerome on topic problem to show icons in vendor panel
For these icons, HikaMarket uses some rules from the HikaShop CSS file.
.icon-48-user {background-image: url(/../images/icons/icon-48-user.png);}
.icon-48-order {background-image:url(../images/icons/icon-48-order.png);}
.icon-48-product {background-image:url(../images/icons/icon-48-product.png);}
.icon-48-category {background-image:url(../images/icons/icon-48-category.png);}
- orchideelab
13 years 3 months ago #117835
by orchideelab
Replied by orchideelab on topic problem to show icons in vendor panel
ok,
icons are in the folder, but I can not see them ...
13 years 3 months ago #117850
by Jerome
You have to check your CSS in your website.
Do you have a custom CSS ?
If so, do you see these rules in your CSS ?
If not, you will have to insert it directly in your hikashop custom CSS file.
Otherwise we will need more information about your website (like a url and a vendor account) in order to check what's wrong.
Please note that HikaMarket 1.2.0 requires HikaShop 2.2.0 or newer.
You note that you have HikaShop 2.1.3 so you might have some compatibility troubles because HikaMarket could use some function or files from HikaShop 2.2.0 which are not present in HikaShop 2.1.3
The HikaShop required version is noted in the change log (and in the release note in our forum).
www.hikashop.com/support/documentation/1...arket-changelog.html
We will see to add warning notices during the installation.
- orchideelab
13 years 3 months ago #117869
by orchideelab
i don't have a custom css.
Rules are in default css.
I've upgraded my HikaShop now but the problem is always present.
I send in your mail info to enter in website
13 years 3 months ago #117965
by Jerome
Your template override the "icon-" rules and set a background-image to "none".
So you have to edit the HikaShop CSS file in order to set the background-image as important for our rules:
.icon-48-order {background-image: url(/../images/icons/icon-48-order.png) !important;}
.icon-48-category {background-image:url(../images/icons/icon-48-category.png) !important;}
.icon-48-user {background-image:url(../images/icons/icon-48-user.png) !important;}
.icon-48-product {background-image:url(../images/icons/icon-48-product.png) !important;}
