Using templates created for other carts
12 years 10 months ago #137750
by sky7
Using templates created for other carts was created by sky7
mywebsite.com/mypage
-- Joomla version -- : x.x
-- PHP version -- : x.x.x
Good day, Can I use templates created for other shopping carts eg. virtumart?
Kind Regards
Kind Regards
12 years 10 months ago #137751
by Jerome
Replied by Jerome on topic Using templates created for other carts
Basically yes, you can but you will have to adapt the template CSS or/and some HikaShop/HikaMarket views in order to improve the integration and have a better final looking.
Some templates made for very specific components can include overrides or very particular modifications for the targeted component.
So the required time for the modifications could vary depending the template you use. It is very hard to say.
12 years 10 months ago #137754
by sky7
Replied by sky7 on topic Using templates created for other carts
Thank you for your prompt response christmas day.
I am using a template from ,
do you know if this might work?
12 years 10 months ago #137791
by Jerome
With time and development, everything is possible.
I take a look at the demo website for the template you use. I can't say that it's impossible but, it could be done but you will have to make a lot of modification in HikaShop or in the template CSS in order to have the same result that their demo website.
I am not a designer/integrator so I am sure that it will take more time for me than for a specialist to do such job but it is an important work.
