Two companies (vendors) in two countries
12 years 5 months ago - 12 years 5 months ago #159970 by Rokell
Thanks Jerome,
I was able to create a custom field for the vendor. I named the table column 'footer'. I have no PHP knowledge. Could you please tell me where to place 'footer' in the code you gave me?
$field = $this->extraFields['vendor']['footer']; $fieldname = $field->field_namekey; echo $this->fieldsClass->show($field, $this->vendor->$fieldname);
Roger
Last edit: 12 years 5 months ago by Jerome. Reason: [code] is nice !!
12 years 5 months ago #159977 by Rokell
product name in invoices
About the translation of the order product names, it's not possible like that ; the names are stored in the database to keep the product name when the order has been made ; so if the product change, the order not (It's an obligation for invoices).
I will suggest you to read other topics in the HikaShop forum (in the HikaShop section). It is HikaShop related and I won't be able to help you here for that problem.
Like I said, it won't be possible.
You have to load the product from the database using the product_id, it is the single and only solution to do that.
OK, but what code do I have to put in the invoice to get the product_id?
Best
Roger
12 years 5 months ago #159981 by Jerome
I edited your post to fix code (and added the code tags to see correctly the brackets).
To load a product, you have to use the HikaShop product class and use the function "get" to get a product.
You will find other threads in this forum which talk about it (but it is HikaShop related, not HikaMarket).
12 years 5 months ago #160080 by Rokell
Hi Jerome,
thanks, the code does work now!
I'll check the product stuff as you suggested in the HikaShop section.
Roger
