Problem with pop-up window ( Fixed )
10 years 7 months ago - 10 years 7 months ago #237764 by neo191987
-- HikaMarket version -- : 1.6.7
Hi I found a little problem with pop-up window of products - translation.
Correct: Popup mode: Vex or mootools
Problem: Popup mode: bootstrap
Last edit: 10 years 7 months ago by neo191987.
10 years 7 months ago #237784 by Jerome
Thanks for the report.
It looks like there is some CSS issues with the bootstrap popup. The backend template includes some CSS for that but not the front-end one. And there is also some missing parameters.
I'll investigate in my local website.
In any cases, Vex is now the recommended popup system in HikaShop and is set by default for new installations.
Squeezebox uses Mootools and Bootstrap is not managed (or partially managed) by templates.
With Vex we are sure that the popup will work and that the CSS is fine.
The following user(s) said Thank You: neo191987
