How to show products from specific vendor group
7 years 3 months ago - 7 years 3 months ago #309896 by nossibe63
-- HikaShop version -- : 4.2.1
-- HikaMarket version -- : 3.0.2
-- Joomla version -- : 3.9.6
-- PHP version -- : 7.2.21
It is possible to give the choice to the user to choose the sellers whose products will be displayed, but is it possible to do so for a predefined group of sellers.
This seller group could be defined by a Joomla user group or by using a custom field (all sellers who have selected the same option will be displayed).
Is it possible according to you? What is the easiest way to achieve this?
Regards :)
Last edit: 7 years 3 months ago by nossibe63.
7 years 3 months ago #309905 by Jerome
With time and development, everything is possible.
In your case, it would require to change how the vendor selector custom field is acting in order to be able to filter the vendors you want to display into. It might require to interact with the namebox system and also add some verification for the vendor assignation to be sure that the customer did not select a value which won't be authorized.
It is some development, it need some PHP en coding skills but it is not a huge or impossible development.
The namebox part is currently the most difficult one to estimate since it could need some tests to choose the best implementation.
7 years 3 months ago #309923 by nossibe63
Thank you Jerome, I will try to develop this :)
