Aus Post Shipping isnt changing shipping charge
15 years 8 months ago #10981
by acballast
Aus Post Shipping isnt changing shipping charge was created by acballast
I have just added a second product to my store with different dimensions and weight to the first product and i have noticed that the calculated shipping cost does not change. Even if i change the shipping address of my test account the price of shipping does not change.
I am currently using HikaShop 1.4.7 and Joomla 1.6.1
Any help would be appreciated.
Thanks,
Ryan
Thanks,
Ryan
15 years 8 months ago #10986
Replied by nicolas on topic Re: Aus Post Shipping isnt changing shipping charge
It's working on our end. Could you give the URL of your website so that we can check it out ?
15 years 8 months ago #10995
by acballast
Replied by acballast on topic Re: Aus Post Shipping isnt changing shipping charge
Sure thing.
The url is www.acballast.com
It may well be a setting that i have missed, but i have been through a few times and cannot find what i am missing.
Thank you for the prompt reply.
Ryan
Ryan
15 years 8 months ago #11002
What weight did you set for your two products and what do you have in the weight unit option of the hikashop configuration ?
15 years 8 months ago #11061
by acballast
When you say the weight unit, do you mean the weight symbols under System -> Main? That is set to kg,g
For the products it is as follows:
IGLOO Down Light Cover (Single Cover)
Weight: 400.000g
Length: 210.000mm
Width: 120.000mm
Height: 110.000mm
IGLOO Down Light Cover (Box 24)
Weight: 6260.000g
Length: 430.000mm
Width: 395.000mm
Height: 410.000mm
Thank you.
Weight: 400.000g
Length: 210.000mm
Width: 120.000mm
Height: 110.000mm
Weight: 6260.000g
Length: 430.000mm
Width: 395.000mm
Height: 410.000mm
Thank you.
15 years 8 months ago #11063
That seems ok. Could you give us an FTP access to your website so that we can put traces in it and check out the problem ?
15 years 8 months ago - 15 years 8 months ago #11065
by acballast
Sure. Is there a way to send a personal message or email address i could send the details to?
Also i can make you a user for the joomla back end if you need it.
Last edit: 15 years 8 months ago by acballast.
15 years 8 months ago #11067
That would be great. You can use our contact form:
www.hikashop.com/en/support/contact-us.html
15 years 8 months ago #11214
The problem was that you used the dimension unit mm for your products but the main unit is m in your config (the first one). HikaShop always convert all the dimensions into the main unit before any calculus (so that everything is in the same unit). However, that resulted in your dimensions being considered as 0 because the numbers were too small.
I just changed the main unit to mm instead of m and it seems that the problem is resolved.
